lre5-lcd2 [2021/01/21 23:29] phatline |
lre5-lcd2 [2023/09/12 14:45] phatline [Building] |
Line 1: | Line 1: | ||
====== LRE5-LCD2 ====== | ====== LRE5-LCD2 ====== | ||
+ | {{:phatline:LRE5-LCD2-Proto-CV1.jpg?500|}}\\ | ||
{{:phatline:LRE5-LCD2-3D-Top.png?500|}}\\ | {{:phatline:LRE5-LCD2-3D-Top.png?500|}}\\ | ||
- | **5Encoders\\ | + | |
- | * 5Ledrings\\ | + | ** * 5 Encoders\\ |
- | * 5ENC-Switchs\\ | + | * 5 Ledrings\\ |
- | * 5x3LEDS for ENC-Switches\\ | + | * 5 ENC-Switchs\\ |
+ | * 5 3LEDS for ENC-Switches\\ | ||
* 1 Shift-Switch\\ | * 1 Shift-Switch\\ | ||
- | * 2x 1306 7Pin- OLED-LCDs**\\ | + | * 2 1306 7Pin- OLED-LCDs**\\ |
controlled from a STM32F4 Microcontroller [[dipcoref4]],[[CV1]]\\ | controlled from a STM32F4 Microcontroller [[dipcoref4]],[[CV1]]\\ | ||
build for CV1 as UI-Expansion-PCB.\\ | build for CV1 as UI-Expansion-PCB.\\ | ||
Line 25: | Line 27: | ||
====== Building ====== | ====== Building ====== | ||
- | The Design is optimized for Pick and Place > all SMD Parts are on the Top-PCB\\ | + | The Design is optimized for Pick and Place > allmost all SMD Parts are on the Top-PCB\\ |
- | The Rest is Thruhole > easy\\ | + | The Rest is Thruhole > easy, the ULN Driver are SMD and has to be handsolderd\\ |
now waiting for Presoldered PCBs\\ | now waiting for Presoldered PCBs\\ | ||
{{:phatline:LRE5-LCD2-PCB.png?500|}}\\ | {{:phatline:LRE5-LCD2-PCB.png?500|}}\\ | ||
+ | 10 assambled pick and place PCBs costs 60€ in 2021... so one PCB costs arround 6€\\ | ||
+ | but we have to add the other parts wich costs 47€ incl taxes incl shipping in 2023.\\ | ||
+ | a big cost is the frontplate which cost 20€... but if you panalize the frontpanel and order more off it you could reduce this costs massive!\\ | ||
+ | so 47+6€= 53€ for one LRE5-LCD2-PCB. exclusive off this calculation are Knops for the Encoders.\\ | ||
===== BOM LCSC===== | ===== BOM LCSC===== | ||
these are the parts which must be handsoldered\\ | these are the parts which must be handsoldered\\ | ||
^Comment^Designator^Footprint^LCSC Part Number^Lot^ | ^Comment^Designator^Footprint^LCSC Part Number^Lot^ | ||
- | |ULN2003ADRW|Q1-Q3|SOIC-18_300mil|C9683|3| | + | |ULN2003ADRW|Q1-Q3|SOIC-18_300mil|C9683 a`ca.0,8€ exclTaxes|3| |
- | |PEC11R-4015F-S24|ENC1-ENC5|tht|C143789|5| | + | |PEC11R-4015F-S24|ENC1-ENC5|tht|C143789[[https://www.mouser.at/ProductDetail/652-PEC11R-4015F-S24|mouser-a 1,94€ exclTaxes]]|5| |
- | |Micromatch-2x5|LCDi1,LCDo1,Ji89,Jo89|tht|C590954|4| | + | |Micromatch-2x5-fema|LCDi1,LCDo1,Ji89,Jo89|tht|C590954 [[https://www.mouser.at/ProductDetail/571-12150830|mouser-a`0,774€ exclTaxes]]|4| |
+ | |Micromatch-2x5-male|LCDi1,LCDo1,Ji89,Jo89|tht|C590954 [[https://www.mouser.at/ProductDetail/571-12150790|mouser-a`0,882€ exclTaxes]]|4| | ||
|Switch|S1|tht|C273513|1| | |Switch|S1|tht|C273513|1| | ||
- | S1 can be stuffed with: Matias, CherryMX, MEC-3FTH9, TL1265\\ | + | **S1 can be stuffed with:** Matias, CherryMX, MEC-3FTH9, TL1265\\ |
- | + | [[https://www.midiphy.com/en/shop/181/General-Parts-Tactile-Switches|Matias@midiphy]] 5pcs = 3,49€ incl Tax excl shipping\\ | |
+ | [[https://www.midiphy.com/en/shop-details/183/103/5pcs-superq-keycap-mechanical-keyboard-alps-matias-keyswitches-keycaps-novelty-blanks-rgb-shine-through-dsa-cherry-mx-single-space-1x1|Caps@midipy]] 5pcs = 10€ incl tax excl shipping\\ | ||
+ | Also you will need one ultrabright LED to illuminate the Matias Switch, the mounting at the moment is a bit diy (hot glue gun)...\\ | ||
===== BOM AliExpress===== | ===== BOM AliExpress===== | ||
- | [[https://de.aliexpress.com/item/32831561142.html?spm=a2g0s.9042311.0.0.27424c4dzZbi5A|2xSSD1306-7Pin]] | + | [[https://de.aliexpress.com/item/32638662748.html?spm=a2g0o.order_list.order_list_main.10.21ef1802NuwRWb&gatewayAdapt=glo2deu|2xSSD1306-7Pin]] - a`1,47€ excl import taxes and shipping. |
Line 60: | Line 69: | ||
+ Ribbon Cables for example (MOUSER):\\ | + Ribbon Cables for example (MOUSER):\\ | ||
710-63911015521CAB|1\\ | 710-63911015521CAB|1\\ | ||
+ | ====== Frontpanel====== | ||
+ | {{:phatline:LRE-OLED-BAR2-Frontpanel-BILD.jpg?700|}}\\ | ||
+ | I made a DXF File which you can send to [[https://www.formulor.de/|Formulor in Germany]]\\ | ||
+ | Here a DXF with one Frontplate, ready to upload to Formulor:\\ | ||
+ | I payed 20€ incl taxes and sipping from Germany to Austria\\ | ||
+ | {{:phatline:Formulor-P1-1xLRE5LCD2.dxf.zip?700|}}\\ | ||
+ | **Recommend Material from Formulor:**\\ | ||
+ | 3mm Acrylglas GS 181x181mm, mittelgrau transparent(7C83)\\ | ||
+ | If you plan to build a MSQ-CC-LRE wit your LRE5LCD2, then you may save money by use this panalized DXF, where 2x LRE5LCD Panels + 2x MSQ-CC-LRE Panels are placed:\\ | ||
+ | {{:phatline:FP-LRE-OLED-2X-EURO-FORMULAR-2xLRE5LCD2.zip?700|}} ready to upload to Formulor:\\ | ||
+ | I payed 45€ incl taxes and sipping from Germany to Austria\\ | ||
+ | 3mm Acrylglas GS 384x384mm, mittelgrau transparent(7C83)\\ | ||
Line 66: | Line 97: | ||
====== To Do ====== | ====== To Do ====== | ||
- | waiting for christmas\\ | + | making Revision 2, because in 1 the Transistor-Array-Fottprint is wrong and had to bridged\\ |
- | UI-PCBs\\ | + | {{:phatline:LRE5-LCD2-Proto-Bridges.jpg?500|}}\\ |
- | Debugging First Version\\ | + | |
====== Community users working on it ====== | ====== Community users working on it ====== |
