m16 [2018/08/09 21:01] antichambre [M16 Interface] |
m16 [2018/10/08 09:08] antichambre [BOM] |
Line 1: | Line 1: | ||
{{ :antichambre:124775m2_ts.png?600 |}} | {{ :antichambre:124775m2_ts.png?600 |}} | ||
- | ====== M16 Interface ====== | + | ====== M16 MIDI Interface ====== |
**Add 16 MIDI I/O to your Core, SPI Slave Interface with up to 16 UARTs(MIDI I/O), based on low-cost FPGA...** | **Add 16 MIDI I/O to your Core, SPI Slave Interface with up to 16 UARTs(MIDI I/O), based on low-cost FPGA...** | ||
- | \\ | + | ==== Features ==== |
- | <wrap round important 7%> | + | |
- | toDo | + | |
- | </wrap> | + | |
- | Some connection examples\\\\ | + | |
- | Spi slave, share protocol | + | |
- | and added commands\\ | + | |
- | Features\\ | + | |
* The FPGA internal clock works @88.67MHz. | * The FPGA internal clock works @88.67MHz. | ||
- | * Fast 4 wires SPI in slave mode to control the board, 10Mb/s. | + | * Fast 4 wires SPI in slave mode to control the board, 10Mb/s, 5V tolerant. |
* Uses the default MIOS32_SPI_MIDI protocol, MIOS32 is ready-to-use with it. | * Uses the default MIOS32_SPI_MIDI protocol, MIOS32 is ready-to-use with it. | ||
* 16 UARTs on board, it's 16 MIDI ports. | * 16 UARTs on board, it's 16 MIDI ports. | ||
Line 24: | Line 14: | ||
* There's a 64 word(32bits) FIFO for out-coming messages from the board. | * There's a 64 word(32bits) FIFO for out-coming messages from the board. | ||
* 3 independents groups of 16 GPIOs, configurable and settable by SPI Command. | * 3 independents groups of 16 GPIOs, configurable and settable by SPI Command. | ||
+ | * Can be stacked under a [[dipboardf4|dipBoardF4]] | ||
+ | {{ :antichambre:1809_m16_interface_v1.beta_top_real.jpg?600 |}} | ||
+ | {{ :antichambre:1809_m16_interface_v1.beta_bottom_real.jpg?600 |}} | ||
+ | ===== PCB===== | ||
+ | <WRAP group> | ||
+ | <WRAP column 60%> | ||
+ | {{ :antichambre:1809_m16_interface_v1.beta_top.png |}} | ||
+ | {{ :antichambre:1809_m16_interface_v1.beta_bottom.png |}} | ||
+ | </WRAP> | ||
+ | <WRAP column 35%> | ||
+ | 2 layers PCB design.\\ | ||
+ | Fits 2 layer mostly common design rules. | ||
+ | * min. drill 10mil | ||
+ | * min. width 6mil | ||
+ | </WRAP>\\ | ||
+ | </WRAP>\\ | ||
+ | ===== Dimension ===== | ||
+ | <WRAP column 70%> | ||
+ | {{:antichambre:m16_interface_v1b.beta_dim.png?600 |}} | ||
+ | </WRAP>\\ | ||
+ | </WRAP>\\ | ||
+ | ===== BOM ===== | ||
+ | version 1. | ||
+ | Mouser BOM:<wrap round todo 7%>toDo</wrap> | ||
+ | ^Qty ^Value ^Package ^Parts^Mouser^Reichelt^Conrad^Other^Notes^ | ||
+ | ^Resistors^^^^^^^^^ | ||
+ | |4 |680R 5% |0603 |R1, R2, R3, R4 |[[https://www.mouser.fr/ProductDetail/Panasonic/ERJ-PA3J681V?qs=sGAEpiMZZMvdGkrng054t6%2fAfIpq60YDGGtXI%252bjCSgEeBlnz3sOAbg%3d%3d| 667-ERJ-PA3J681V | ||
+ | ]] | | | |Depends on Leds | | ||
+ | ^Capacitors^^^^^^^^^ | ||
+ | |3 |10n |0603|C27, C29, C30 | | | | | | | ||
+ | |15 |100n |0603|C23, C24, C28, C31, C32, C33, C34, C35, C36, C37, C38, C39, C40, C41, C42 |[[https://www.mouser.fr/ProductDetail/KEMET/C0603C104Z3VACTU?qs=sGAEpiMZZMs0AnBnWHyRQFqPnX0Olvco%252bYoiWDWTaEY%3d| 80-C0603C104Z3V | ||
+ | |2 |10u |SMC_B |C25, C26|[[https://www.mouser.fr/ProductDetail/AVX/F931C106MAA?qs=sGAEpiMZZMuEN2agSAc2puC4lhRhLeolmYomTIpwaLE%3d| | ||
+ | 647-F931C106MAA ]] | | | | | | ||
+ | ^LEDs^^^^^^^^^ | ||
+ | |4 |--|0805 |LED.1, LED.2, LED.31, LED.4 |[[https://www.mouser.fr/ProductDetail/755-SML-H12U8TT86C|755-SML-H12U8TT86C]] | | | | | | ||
+ | ^ICs^^^^^^^^^ | ||
+ | |1 |LCMX02-7000|TQFP144|FPGA |[[https://www.mouser.fr/ProductDetail/Lattice/LCMXO2-7000HC-6TG144I?qs=sGAEpiMZZMvoScKlWpK8TKmOIJyZBaKlkPc%2f7GsJudw%3d|842-27000HC6TG144I ]] | | | |Speed grade 4 to 6, 3.3V! | | ||
+ | |1 |74LVC125 |TSSOP-14 |IC4 |[[https://www.mouser.fr/ProductDetail/Texas-Instruments/SN74LVC125APWR?qs=sGAEpiMZZMuiiWkaIwCK2SeqB8b8eM7HVlo3jiw3ikc%3d|595-SN74LVC125APWR ]] | | | | | | ||
+ | |1 |LD1117AS33TR|SOT223 |REG |[[https://www.mouser.fr/ProductDetail/STMicroelectronics/LD1117AS33TR?qs=sGAEpiMZZMsGz1a6aV8DcLVRTmaeOdDgNH1NaHTUtDw%3d| | ||
+ | 511-LD1117AS33 ]] | | | | | | ||
+ | ^Connnector^^^^^^^^^ | ||
+ | |1 |micro-match 2x2 |Male |J1B |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/215464-4?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLgKRfGxhAt6V0%3d|571-215464-4 ]] | | | |for stack | | ||
+ | |1 |2x3 |Male |J1A |[[https://www.mouser.fr/ProductDetail/Wurth-Electronics/61200621621?qs=sGAEpiMZZMs%252bGHln7q6pm%2fFhW%252btWvhAgbNxkR%252blwXp8Ip%2fAN9J9VOg%3d%3d|710-61200621621 ]] | | | | | | ||
+ | |1 |micro-match 2x3 |Female |JTAG |[[https://www.mouser.fr/ProductDetail/TE-Connectivity/215079-6?qs=sGAEpiMZZMs%252bGHln7q6pm48SVpWlpfsECZqIi2rkWjs%3d|571-215079-6]] or [[https://www.mouser.fr/ProductDetail/TE-Connectivity/2178710-6?qs=sGAEpiMZZMs%252bGHln7q6pmzszEaJ39Bz8lDoKaCIVjpqtoiZwdtC2Ng%3d%3d|571-2178710-6 (value line)]] | | | | | | ||
+ | |5 |2x5 |Male |J11A, J11B, J11C, J11D, SPI |[[https://www.mouser.fr/ProductDetail/Wurth-Electronics/61201021621?qs=sGAEpiMZZMs%252bGHln7q6pm%252bxnWLfLL2%2f93mYWvuMVZAY%3d|710-61201021621 ]] | | | | | | ||
+ | |1 |micro-match 2x5 |Male |SPI |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/8-215464-0?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLgIDcXiC5FL8s%3d| | ||
+ | 571-8-215464-0 ]] | | | |for stack | | ||
+ | |5 |2x10 |Male |GPIOA, GPIOB, GPIOC |[[https://www.mouser.fr/ProductDetail/Wurth-Electronics/61202021621?qs=sGAEpiMZZMs%252bGHln7q6pm%252bxnWLfLL2%2f9xQYuWgvWHoc%3d|710-61202021621 ]] | | | | | | ||
+ | ===== SPI Communication and protocol ===== | ||
+ | **This protocol is already implemented in MIOS32 as MIOS32_SPI_MIDI functions.**\\ | ||
+ | This is a SPI slave interface.\\ | ||
+ | Host communication protocol is based on MMA Specification for USB communication.\\ | ||
+ | MIDI data is carried in the packet in 32 bit MIDI Event. Most common MIDI messages are 2 or 3 bytes | ||
+ | packed into one MIDI Event.\\ | ||
+ | Longer messages, generally System Exclusive messages are carried in multiple MIDI | ||
+ | Events. These MIDI Event provide a method to transfer MIDI messages with 32 bit fixed length messages to help | ||
+ | memory allocation. This also makes parsing MIDI events easier by packetizing the separate bytes of a MIDI | ||
+ | message into one parsed MIDI Event.\\ | ||
+ | The first byte in each 32-bit MIDI Event is a sub-header containing a Port Index Number (4 bits) followed | ||
+ | by a Code Index Number (4 bits). The remaining three bytes contain the actual MIDI event. Most typical parsed | ||
+ | MIDI events are two or three bytes in length. Unused bytes are reserved and must be padded with zeros (in the | ||
+ | case of a one- or two-byte MIDI event) to preserve the 32-bit fixed length of the MIDI Event.\\ | ||
+ | The Code Index Number (CIN) indicates the classification of the bytes in the and the number of bytes in the message. The following table summarizes these classifications.\\ | ||
+ | <code c> | ||
+ | //! this global array is read from MIOS32_MIDI to | ||
+ | //! determine the number of MIDI bytes which are part of a package | ||
+ | const u8 mios32_midi_pcktype_num_bytes[16] = { | ||
+ | 0, // 0: invalid/reserved event | ||
+ | 0, // 1: local command | ||
+ | 2, // 2: two-byte system common messages like MTC, Song Select, etc. | ||
+ | 3, // 3: three-byte system common messages like SPP, etc. | ||
+ | 3, // 4: SysEx starts or continues | ||
+ | 1, // 5: Single-byte system common message or sysex sends with following single byte | ||
+ | 2, // 6: SysEx sends with following two bytes | ||
+ | 3, // 7: SysEx sends with following three bytes | ||
+ | 3, // 8: Note Off | ||
+ | 3, // 9: Note On | ||
+ | 3, // a: Poly-Key Press | ||
+ | 3, // b: Control Change | ||
+ | 2, // c: Program Change | ||
+ | 2, // d: Channel Pressure | ||
+ | 3, // e: PitchBend Change | ||
+ | 1 // f: single byte | ||
+ | </code> | ||
+ | ===== MIDI messages ===== | ||
+ | Running status is never used, so all the messages are formed of all bytes. But the interface supports it, each MIDI Out can be individually set for that purpose.\\ | ||
+ | ==== Some examples ==== | ||
+ | **MIDI clock on port 7(SPIM0 to SPIM15)**\\ | ||
+ | MIDI message is 0xF8, cin = 0x5.\\ | ||
+ | SPI message = 0x0000f875 (Less significant byte first)\\ | ||
+ | <code c> | ||
+ | mios32_midi_package_t package; | ||
+ | package.ALL = 0; | ||
+ | package.cin = 0x5; // Single-byte system common message | ||
+ | package.evnt0 = 0xf8; // MIDI Clock event status | ||
+ | MIOS32_MIDI_SendPackage(SPIM7, package); | ||
+ | // or directly | ||
+ | MIOS32_MIDI_SendClock(SPIM7); | ||
+ | </code> | ||
+ | **Note On on port 11**\\ | ||
+ | MIDI message is 0x90 0x2A 0x40, cin = 0x9.\\ | ||
+ | SPI message = 0x402A90b9\\ | ||
+ | <code c> | ||
+ | package.cin = 0x9; // Single-byte system common message | ||
+ | package.evnt0 = 0x90; // MIDI Note On event, channel 1 | ||
+ | package.evnt1 = 0x2A; // Note Number | ||
+ | package.evnt2 = 0x40; // Velocity | ||
+ | MIOS32_MIDI_SendPackage(SPIM11, package); | ||
+ | MIOS32_MIDI_SendNoteOn(SPIM11, Chn1, 0x2A, 0x40) | ||
+ | </code> | ||
+ | **System Exclusive on port 0**\\ | ||
+ | MIDI message is 0xF0 0x01 0x02 0x03 0x04 0x05 0xF7.\\ | ||
+ | The stream will be divided in 3 packages:\\ | ||
+ | SPI messages = 0x0101f004(SYSEX start), 0x05040304(SYSEX continues), 0x0000f705(SYSEX ends with one byte) | ||
+ | <code c> | ||
+ | package.cin = 0x4; // Single-byte system common message | ||
+ | package.evnt0 = 0xf0; // Start of Exclusive | ||
+ | package.evnt1 = 0x01; // Data | ||
+ | package.evnt2 = 0x02; // Data | ||
+ | MIOS32_MIDI_SendPackage(SPIM0, package); | ||
+ | package.evnt0 = 0x03; // Data | ||
+ | package.evnt1 = 0x04; // Data | ||
+ | package.evnt2 = 0x05; // Data | ||
+ | package.evnt0 = 0xf7; // End of Exclusive | ||
+ | u8 stream[7]={0xF0, 0x01, 0x02, 0x03, 0x04, 0x05, 0xF7}; | ||
+ | MIOS32_MIDI_SendSysex(SPIM0, (u8*)stream, 7); | ||
+ | </code> | ||
+ | ==== Special command messages ==== | ||
+ | The **m16** can receive some specifics commands and send back some status messages.\\ | ||
+ | when **CIN=0x1**(local command), the **m16** will parse the message as a command and apply the requested change.\\ | ||
+ | * Port(Cable)value becomes Group Command Code(GCC).\\ | ||
+ | * evnt0 is the command number(CMD.\\ | ||
+ | * evnt1 and evnt2 are the value bytes.\\ | ||
+ | List of the commands:\\ | ||
+ | <WRAP column 100%> | ||
+ | {{:antichambre:cmd_table.png|}} | ||
+ | </WRAP>\\ | ||
+ | </WRAP>\\ | ||
+ | With System commands, you will be able to | ||
+ | * Put SPI or UARTs in loopback for testing purpose. | ||
+ | * Enable MIDI activity status messages over SPI(MISO). | ||
+ | There's only one MIDI configuration command, dedicated to UARTs TX(MIDI Out) Running Status enabler.\\ | ||
+ | With GPIOx commands, you can configure and set the GPIO ports.\\ | ||
+ | <wrap round important 7%> | ||
+ | toDo | ||
+ | </wrap> | ||
+ | Some connection examples\\\\ | ||
In MIOS32\\ | In MIOS32\\ | ||
datasheet\\ | datasheet\\ |
