Both sides previous revision Previous revision | Next revision Both sides next revision | ||
m16 [2018/09/08 13:16] antichambre [Dimension] |
m16 [2018/09/08 13:56] antichambre [Special command messages] |
Line 145: | Line 145: | ||
The **m16** can receive some specifics commands and send back some status messages.\\ | The **m16** can receive some specifics commands and send back some status messages.\\ | ||
when **CIN=0x1**(local command), the **m16** will parse the message as a command and apply the requested change.\\ | when **CIN=0x1**(local command), the **m16** will parse the message as a command and apply the requested change.\\ | ||
- | * Port(Cable)value becomes Group Command Code.\\ | + | * Port(Cable)value becomes Group Command Code(GCC).\\ |
- | * evnt0 is the command number.\\ | + | * evnt0 is the command number(CMD.\\ |
* evnt1 and evnt2 are the value bytes.\\ | * evnt1 and evnt2 are the value bytes.\\ | ||
List of the commands:\\ | List of the commands:\\ |
