mb-digiroland [2016/08/14 22:38] phatline [Community users working on it] |
mb-digiroland [2016/11/12 17:06] psykhaze [MIDI Use] |
Line 1: | Line 1: | ||
- | ====== MIDIbox EuRoland Project ====== | + | ====== MIDIbox DigiRoland Project ====== |
- | {{:neonking:euroland-logo.jpg?direct&600 |}} | + | |
- | The Midibox EuRoland project aims to be a **Eurorack Re-Edit of Analog Drum Parts of Roland TR Drumachines** designed to fit in the Eurorack size Format, to be driven trought MIDI or CV. | + | The Midibox EuRoland project aims to be a **4U Re-Edit of Analog Drum Parts of Roland TR Drumachines** designed to fit in the Eurorack size Format, to be driven trought MIDI or CV. |
It's the Merging of these projects: | It's the Merging of these projects: | ||
Line 11: | Line 10: | ||
* [[mb-606re|MB-606RE]] | * [[mb-606re|MB-606RE]] | ||
* [[mb-808re|MB-808RE]] | * [[mb-808re|MB-808RE]] | ||
- | * [[mb-909re|MB-909RE]] | + | |
===== Community users working on it ===== | ===== Community users working on it ===== | ||
Line 17: | Line 16: | ||
* **[[Phatline]]** | * **[[Phatline]]** | ||
* **[[Psykhaze]]** | * **[[Psykhaze]]** | ||
- | + | * **[[Antichambre]]** | |
- | **Workshare:**\\ | + | |
- | **909**\\ | + | |
- | RIM + SNARE > PHATLINE\\ | + | |
- | TOMs + BD + SAMPLER-Voices > Psykhaze\\ | + | |
- | **808:**\\ | + | |
- | TOMS + BD + SD > Psykhaze\\ | + | |
- | CY + HH +COWBELL > PHATLINE\\ | + | |
- | **606**\\ | + | |
- | CY+HH > PHATLINE\\ | + | |
- | BD+SD > Psykhaze\\ | + | |
===== Getting Involved ? ===== | ===== Getting Involved ? ===== | ||
Line 39: | Line 26: | ||
2 Cases of use :\\ | 2 Cases of use :\\ | ||
- | * **1. Midi:** Use the MB-Modulbox Standartmodules, for Digital UI and CV+Trig-Generation\\ | + | * **1. Midi-Interface:** Use the MB-Modulbox Standartmodules, for Digital UI and CV+Trig-Generation\\ |
- | * **2. CV+Trig:** Just Plug CV or Trig Jacks into the Analog Modules...without Midibox.\\ | + | * **2. Analog Interface:** Just Plug CV or Trig Jacks into the Analog Modules...without Midibox.\\ |
- | ==== Use with Midi ==== | + | ===== Workshare ===== |
+ | ====606==== | ||
+ | BD+SD > [[Psykhaze]]\\ | ||
+ | CY+HH > [[Phatline]]\\ | ||
+ | ====808==== | ||
+ | BD, SD, TOM > [[Psykhaze]]\\ | ||
+ | CY, HH, COWBELL > [[Phatline]]\\ | ||
+ | ====909==== | ||
+ | BD, TOM, SAMPLER-Voices > [[Psykhaze]]\\ | ||
+ | SD, RIM > [[Phatline]]\\ | ||
- | === MB-Modulbox Main PCB UI === | + | ===== Configuration ===== |
+ | ==== MIDI Use ==== | ||
+ | === Main PCB UI === | ||
**Access** to System-Settings, Channel, NoteNumbers\\ | **Access** to System-Settings, Channel, NoteNumbers\\ | ||
**CV+Trig Out-Jacks** for Euroland Drum Modules \\ | **CV+Trig Out-Jacks** for Euroland Drum Modules \\ | ||
- | === MB-Modulbox 8xPotentiometer Module === | + | === 8xPotentiometer Module === |
When using the Euroland Modules via Midi, then there are some Performance Parameters aviable:\\ | When using the Euroland Modules via Midi, then there are some Performance Parameters aviable:\\ | ||
Line 68: | Line 68: | ||
Set CV + Trig Routing (some kind of trigger matrix), standard is 1:1 routing, so no need for this if you use a fixed setup. | Set CV + Trig Routing (some kind of trigger matrix), standard is 1:1 routing, so no need for this if you use a fixed setup. | ||
- | ==== Use with Midi or with Analog CV+Trig ==== | + | ==== Analog Use ==== |
Here are only the Analog-Drum-PCB discussed, since all other Digital UI is based on MB-Modulbox Standart Modules, the MB-Modulbox Main PCB2 is special Variant, described here. | Here are only the Analog-Drum-PCB discussed, since all other Digital UI is based on MB-Modulbox Standart Modules, the MB-Modulbox Main PCB2 is special Variant, described here. | ||
===== Software Tools used ===== | ===== Software Tools used ===== | ||
Line 76: | Line 77: | ||
* **[[kicad|KiCAD PCB]]** - PCB Design | **[[http://smisioto.no-ip.org/elettronica/kicad/kicad-en.htm|KiCAD Librairies]]** | * **[[kicad|KiCAD PCB]]** - PCB Design | **[[http://smisioto.no-ip.org/elettronica/kicad/kicad-en.htm|KiCAD Librairies]]** | ||
* **[[codeblocks_ide|Code::Blocks Integrated Development environment]]** - MIOS programming | * **[[codeblocks_ide|Code::Blocks Integrated Development environment]]** - MIOS programming | ||
- | ===== Eurorack Relative ===== | ||
- | * **Eurorack Design 3U Height **//=5,25"=133mm-rails=__**128,5mm**__// . | ||
- | * **Modules Frontpanels are 8HP-multiple wide** //(8HP=__**40,3mm**__)// see //**[[http://www.doepfer.de/a100_man/a100m_e.htm|Eurorack Specification]]**//. \\ Frontpanel back spacers glued with JB-weld to avoid front screwing. **{{::neonking:eurotemplates.pdf|Eurorack Templates PDF}} | {{::neonking:eurotemplates.zip|Eurorack Templates DXF}}**\\ | ||
- | * **PCB Size is 100mm height** To stay compliant to **//[[http://www.elma.com/en/services/us-resources/eurocard-specs/|Eurocard Specification]]//** | ||
