mb-digiroland [2016/08/15 00:39] psykhaze [General Design] |
mb-digiroland [2016/11/12 17:05] psykhaze [Eurorack Relative] |
Line 1: | Line 1: | ||
- | ====== MIDIbox EuRoland Project ====== | + | ====== MIDIbox DigiRoland Project ====== |
- | {{:neonking:euroland-logo.jpg?direct&600 |}} | + | |
- | The Midibox EuRoland project aims to be a **Eurorack Re-Edit of Analog Drum Parts of Roland TR Drumachines** designed to fit in the Eurorack size Format, to be driven trought MIDI or CV. | + | The Midibox EuRoland project aims to be a **4U Re-Edit of Analog Drum Parts of Roland TR Drumachines** designed to fit in the Eurorack size Format, to be driven trought MIDI or CV. |
It's the Merging of these projects: | It's the Merging of these projects: | ||
Line 11: | Line 10: | ||
* [[mb-606re|MB-606RE]] | * [[mb-606re|MB-606RE]] | ||
* [[mb-808re|MB-808RE]] | * [[mb-808re|MB-808RE]] | ||
- | * [[mb-909re|MB-909RE]] | + | |
===== Community users working on it ===== | ===== Community users working on it ===== | ||
Line 17: | Line 16: | ||
* **[[Phatline]]** | * **[[Phatline]]** | ||
* **[[Psykhaze]]** | * **[[Psykhaze]]** | ||
+ | * **[[Antichambre]]** | ||
===== Getting Involved ? ===== | ===== Getting Involved ? ===== | ||
Line 23: | Line 23: | ||
===== General Design ===== | ===== General Design ===== | ||
- | {{ ::neonking:euroland-sandwich.jpg?800 |}} | ||
2 Cases of use :\\ | 2 Cases of use :\\ | ||
Line 45: | Line 43: | ||
==== MIDI Use ==== | ==== MIDI Use ==== | ||
- | {{ :neonking:euroland-fp-main.jpg?600 |}} | + | |
=== MB-Modulbox Main PCB UI === | === MB-Modulbox Main PCB UI === | ||
Line 79: | Line 77: | ||
* **[[kicad|KiCAD PCB]]** - PCB Design | **[[http://smisioto.no-ip.org/elettronica/kicad/kicad-en.htm|KiCAD Librairies]]** | * **[[kicad|KiCAD PCB]]** - PCB Design | **[[http://smisioto.no-ip.org/elettronica/kicad/kicad-en.htm|KiCAD Librairies]]** | ||
* **[[codeblocks_ide|Code::Blocks Integrated Development environment]]** - MIOS programming | * **[[codeblocks_ide|Code::Blocks Integrated Development environment]]** - MIOS programming | ||
- | ===== Eurorack Relative ===== | ||
- | * **Eurorack Design 3U Height **//=5,25"=133mm-rails=__**128,5mm**__// . | ||
- | * **Modules Frontpanels are 8HP-multiple wide** //(8HP=__**40,3mm**__)// see //**[[http://www.doepfer.de/a100_man/a100m_e.htm|Eurorack Specification]]**//. \\ Frontpanel back spacers glued with JB-weld to avoid front screwing. **{{::neonking:eurotemplates.pdf|Eurorack Templates PDF}} | {{::neonking:eurotemplates.zip|Eurorack Templates DXF}}**\\ | ||
- | * **PCB Size is 100mm height** To stay compliant to **//[[http://www.elma.com/en/services/us-resources/eurocard-specs/|Eurocard Specification]]//** | ||
