mb-lre8x2cs_pcb [2013/01/17 14:39] fairlightiii Cleaning page |
mb-lre8x2cs_pcb [2016/06/22 00:03] psykhaze [PCB] |
Line 1: | Line 1: | ||
- | ===== MB-LRE8x2CS PCB / 16 LEDrings/Encoders Control Surface===== | + | ====== MB-LRE8x2CS PCB / 16 LEDrings/Encoders Control Surface ====== |
Welcome to the wiki page of the control surface board featuring combo DINx4 and improved DOUTx4 modules with 16 LEDrings and 16 encoders. | Welcome to the wiki page of the control surface board featuring combo DINx4 and improved DOUTx4 modules with 16 LEDrings and 16 encoders. | ||
Line 9: | Line 9: | ||
It is a very practical and cheap way to make a midi controller with adding only a core or make a more important controller without having to wire LEDrings. | It is a very practical and cheap way to make a midi controller with adding only a core or make a more important controller without having to wire LEDrings. | ||
- | ==== PCB ==== | + | ===== PCB ===== |
The PCB have components soldered on the two sides.\\ | The PCB have components soldered on the two sides.\\ | ||
Line 142: | Line 142: | ||
|Kingbright WP103HD|5x2x7mm rectangular|[[http://fr.mouser.com/ProductDetail/Kingbright/WP103HD/?qs=sGAEpiMZZMs4quMj8r4lmhjquLrW8G4%252b6fJ5ym%2fib3s%3d|Mouser]]| | X | |Tk| | |Kingbright WP103HD|5x2x7mm rectangular|[[http://fr.mouser.com/ProductDetail/Kingbright/WP103HD/?qs=sGAEpiMZZMs4quMj8r4lmhjquLrW8G4%252b6fJ5ym%2fib3s%3d|Mouser]]| | X | |Tk| | ||
|LED 3MM RT|3mm round|[[http://www.reichelt.de/LEDs-standard-hell/LED-3MM-RT/3/index.html?;ACTION=3;LA=446;ARTICLE=10228;GROUPID=3018;artnr=LED+3MM+RT|Reichelt]]| X | | |Tk| | |LED 3MM RT|3mm round|[[http://www.reichelt.de/LEDs-standard-hell/LED-3MM-RT/3/index.html?;ACTION=3;LA=446;ARTICLE=10228;GROUPID=3018;artnr=LED+3MM+RT|Reichelt]]| X | | |Tk| | ||
- | |"10001"|5x2x7mm rectangular|[[http://www.auspiciousmall.com/index.php?main_page=product_info&cPath=78_1_2&products_id=19|auspiciousmall.com]]| | X | |Fairlightiii| | + | |"10001"|5x2x7mm rectangular|[[http://www.auspiciousmall.com/index.php?main_page=product_info&cPath=78_1_2&products_id=19|auspiciousmall.com]]| X | X |Used without ULNs(prototype)|Fairlightiii| |
|Kingbright L-934ID|3mm round|[[http://www.segor.de/#Q=LED%203%20rt%20diffus%2050mcd%20630 | |Kingbright L-934ID|3mm round|[[http://www.segor.de/#Q=LED%203%20rt%20diffus%2050mcd%20630 | ||
|Segor Electronics]]| X | | |rvlt| | |Segor Electronics]]| X | | |rvlt| | ||
+ | |Kingbright WP132XID|3mm round|[[http://fr.mouser.com/ProductDetail/Kingbright/WP132XID/?qs=sGAEpiMZZMs4quMj8r4lmsNxrQ0ZQMdoZ/c/v7yOhNA= |Mouser]]| X | |Used without ULNs|grizz| | ||
+ | |Kingbright WP132XID|3mm round|[[http://de.mouser.com/ProductDetail/Kingbright/WP132XID/?qs=sGAEpiMZZMs4quMj8r4lmsNxrQ0ZQMdoZ%2fc%2fv7yOhNA%3d |Mouser]]| | X |Used withMIDIbox NG & ULNs|MaG2k| | ||
+ | |Kingbright WP113SRDT|5x2x7mm rectangular|[[http://de.mouser.com/ProductDetail/Kingbright/WP113SRDT/?qs=%2fha2pyFadugD%2fTsmQfHeoZzOEu7l2adZD53TPtc4aU1OtJcXIaccXQ%3d%3d |Mouser]]| | X |Used withMIDIbox NG & ULNs|MaG2k| | ||
+ | |smashTV is selling|3mm round|[[http://www.avishowtech.com/buy.html |smashTV]]| | X |Used withMIDIbox NG & ULNs|MaG2k| | ||
+ | |Tayda Electronics|3mm round|[[http://www.taydaelectronics.com/leds/round-leds/3mm-leds/led-3mm-red.html |Tayda Electronics]]| X | |Used withMIDIbox NG & ULNs|MaG2k| | ||
====Components==== | ====Components==== | ||
Line 219: | Line 223: | ||
With the use of the upcoming [[http://www.ucapps.de/midibox_ng.html |MIDIbox NG]] (planned for Winter 2012/13) you will be able to have 2 chains of 4 boards each (2x4x16=128 encoders and 2x4x16=128 LEDrings). | With the use of the upcoming [[http://www.ucapps.de/midibox_ng.html |MIDIbox NG]] (planned for Winter 2012/13) you will be able to have 2 chains of 4 boards each (2x4x16=128 encoders and 2x4x16=128 LEDrings). | ||
+ | ====Whishlist==== | ||
+ | For an eventual next revision of the PCB, this is a list of improvements that members are free to complete: | ||
+ | * <del>Changing IN/OUT sockets by polarized sockets and improving the silkscreen (to avoid confusing SI/SO pin)</del>. //Tk// **Done** | ||
+ | * <del>Moving cap C5 (too close to the IN socket)</del>. //Tk// **Done** | ||
+ | * <del>Trying to move some critical vias</del>. //Fairlightiii// **Done** | ||
+ | * What about the use of ULN2803s? //Fairlightiii// **Let them here for 8x2 configuration, not present on upcoming 4x2 and 8x1 boards** | ||
+ | * Trying to add DINX2 onboard to handle the 16 encoder switches (start/end of the chain?). //Fairlightiii// **Not planned to be implemented** | ||
+ | * What about the size of the PCB? //Fairlightiii// **Slightly less big (I won some mm in the edges)** | ||
+ | * new arrangment of encoders and LED-rings in 4x4 matrix? //MaG2k// **Upcoming 4x2 and 8x1 boards** |
