mb-lre8x2cs_pcb [2013/02/05 13:48] fairlightiii [Whishlist] |
mb-lre8x2cs_pcb [2016/06/22 00:03] psykhaze [PCB] |
Line 1: | Line 1: | ||
- | ===== MB-LRE8x2CS PCB / 16 LEDrings/Encoders Control Surface===== | + | ====== MB-LRE8x2CS PCB / 16 LEDrings/Encoders Control Surface ====== |
Welcome to the wiki page of the control surface board featuring combo DINx4 and improved DOUTx4 modules with 16 LEDrings and 16 encoders. | Welcome to the wiki page of the control surface board featuring combo DINx4 and improved DOUTx4 modules with 16 LEDrings and 16 encoders. | ||
Line 9: | Line 9: | ||
It is a very practical and cheap way to make a midi controller with adding only a core or make a more important controller without having to wire LEDrings. | It is a very practical and cheap way to make a midi controller with adding only a core or make a more important controller without having to wire LEDrings. | ||
- | ==== PCB ==== | + | ===== PCB ===== |
The PCB have components soldered on the two sides.\\ | The PCB have components soldered on the two sides.\\ | ||
Line 146: | Line 146: | ||
|Segor Electronics]]| X | | |rvlt| | |Segor Electronics]]| X | | |rvlt| | ||
|Kingbright WP132XID|3mm round|[[http://fr.mouser.com/ProductDetail/Kingbright/WP132XID/?qs=sGAEpiMZZMs4quMj8r4lmsNxrQ0ZQMdoZ/c/v7yOhNA= |Mouser]]| X | |Used without ULNs|grizz| | |Kingbright WP132XID|3mm round|[[http://fr.mouser.com/ProductDetail/Kingbright/WP132XID/?qs=sGAEpiMZZMs4quMj8r4lmsNxrQ0ZQMdoZ/c/v7yOhNA= |Mouser]]| X | |Used without ULNs|grizz| | ||
+ | |Kingbright WP132XID|3mm round|[[http://de.mouser.com/ProductDetail/Kingbright/WP132XID/?qs=sGAEpiMZZMs4quMj8r4lmsNxrQ0ZQMdoZ%2fc%2fv7yOhNA%3d |Mouser]]| | X |Used withMIDIbox NG & ULNs|MaG2k| | ||
+ | |Kingbright WP113SRDT|5x2x7mm rectangular|[[http://de.mouser.com/ProductDetail/Kingbright/WP113SRDT/?qs=%2fha2pyFadugD%2fTsmQfHeoZzOEu7l2adZD53TPtc4aU1OtJcXIaccXQ%3d%3d |Mouser]]| | X |Used withMIDIbox NG & ULNs|MaG2k| | ||
+ | |smashTV is selling|3mm round|[[http://www.avishowtech.com/buy.html |smashTV]]| | X |Used withMIDIbox NG & ULNs|MaG2k| | ||
+ | |Tayda Electronics|3mm round|[[http://www.taydaelectronics.com/leds/round-leds/3mm-leds/led-3mm-red.html |Tayda Electronics]]| X | |Used withMIDIbox NG & ULNs|MaG2k| | ||
====Components==== | ====Components==== | ||
Line 229: | Line 232: | ||
* <del>Moving cap C5 (too close to the IN socket)</del>. //Tk// **Done** | * <del>Moving cap C5 (too close to the IN socket)</del>. //Tk// **Done** | ||
* <del>Trying to move some critical vias</del>. //Fairlightiii// **Done** | * <del>Trying to move some critical vias</del>. //Fairlightiii// **Done** | ||
- | * What about the use of ULN2803s? //Fairlightiii// | + | * What about the use of ULN2803s? //Fairlightiii// **Let them here for 8x2 configuration, not present on upcoming 4x2 and 8x1 boards** |
- | * Trying to add DINX2 onboard to handle the 16 encoder switches (start/end of the chain?). //Fairlightiii// | + | * Trying to add DINX2 onboard to handle the 16 encoder switches (start/end of the chain?). //Fairlightiii// **Not planned to be implemented** |
- | * What about the size of the PCB? //Fairlightiii// | + | * What about the size of the PCB? //Fairlightiii// **Slightly less big (I won some mm in the edges)** |
- | * new arrangment of encoders and LED-rings in 4x4 matrix? //MaG2k// | + | * new arrangment of encoders and LED-rings in 4x4 matrix? //MaG2k// **Upcoming 4x2 and 8x1 boards** |
