Both sides previous revision Previous revision | Last revision Both sides next revision | ||
mb-lre8x2cs_pcb [2016/06/22 00:02] psykhaze [MB-LRE8x2CS PCB / 16 LEDrings/Encoders Control Surface] |
mb-lre8x2cs_pcb [2016/06/22 00:03] psykhaze [PCB] |
Line 9: | Line 9: | ||
It is a very practical and cheap way to make a midi controller with adding only a core or make a more important controller without having to wire LEDrings. | It is a very practical and cheap way to make a midi controller with adding only a core or make a more important controller without having to wire LEDrings. | ||
- | ==== PCB ==== | + | ===== PCB ===== |
The PCB have components soldered on the two sides.\\ | The PCB have components soldered on the two sides.\\ |
