Both sides previous revision Previous revision | |||
mb-lre8x2cs_pcb [2016/06/22 00:03] psykhaze [PCB] |
mb-lre8x2cs_pcb [2016/06/22 00:03] psykhaze [Pictures] |
Line 20: | Line 20: | ||
The diameter of each LEDring is 1,299 inch (33 mm) with the use of 3mm LED.\\ | The diameter of each LEDring is 1,299 inch (33 mm) with the use of 3mm LED.\\ | ||
- | ====Pictures==== | + | =====Pictures===== |
==Protoboard (note this is not the last version but has same dimensions and LEDs/Encoders positioning):== | ==Protoboard (note this is not the last version but has same dimensions and LEDs/Encoders positioning):== |
