mb-modulbox-ng [2016/08/10 04:16] psykhaze [Frontpanels Layouts] |
mb-modulbox-ng [2016/08/15 00:46] psykhaze [MB-ModulBox NG] |
Line 3: | Line 3: | ||
{{ ::neonking:modulbox-logo.jpg?direct&600 |}} | {{ ::neonking:modulbox-logo.jpg?direct&600 |}} | ||
- | // <wrap info> Under Heavy Developpment @ **9/8/2016** </wrap>// | + | // <wrap info> Under Heavy Developpment @ **15/8/2016** </wrap>// |
Line 88: | Line 88: | ||
^ Module ^ N° ^ Analog ^ LED ^Encoders ^ Switches ^HP ^ User ^ Display^ | ^ Module ^ N° ^ Analog ^ LED ^Encoders ^ Switches ^HP ^ User ^ Display^ | ||
- | |Main UI+Main PCB|1 |Jacksx16 | |x1 PushRotary|Tactilex6 |24 |Psykhaze|Graphic-OLEDx1| | + | |Main UI+Main PCB|1 |Jacksx16 | |x1 PushRotary|Tactilex6 |24 |Psykhaze/Latigid|Graphic-OLEDx1| |
- | |Horizontal 4xOLEDS SCSE|2 | | |x1 PushRotary|Tactilex7 |24 | |Small-OLEDx4| | + | |OLED-SCS |2 | | |x1 PushRotary|Tactilex6 |24 |Latigid |Small-OLEDx1->8| |
- | |Vertical 4xOLEDS|3 | | | | |16 | |Small-OLEDx4 | | + | |Vertical 4xOLEDS|3 | | | | |16 |Latigid |Small-OLED x4 | |
|LCD Vertical SCS|4 | | |x1 PushRotary|Tactilex(4+4+2)|16| |CLCD 20x4| | |LCD Vertical SCS|4 | | |x1 PushRotary|Tactilex(4+4+2)|16| |CLCD 20x4| | ||
|LCD Horizontal Extended SCS|5 | | |x2 PushRotary|Tactilex22 |32 |Psykhaze|2xCLCD 40x4| | |LCD Horizontal Extended SCS|5 | | |x2 PushRotary|Tactilex22 |32 |Psykhaze|2xCLCD 40x4| | ||
Line 112: | Line 112: | ||
|Crosspoint Matrix 8x4(x4)|23|Jacksx(8+4)|x(8x4) 3mm | |Toggle 4poles, Tactilex(8+4)|16|Psykhaze| | | |Crosspoint Matrix 8x4(x4)|23|Jacksx(8+4)|x(8x4) 3mm | |Toggle 4poles, Tactilex(8+4)|16|Psykhaze| | | ||
|Adafruit Silicon 3mm 8x8 Matrix|24| |x(8x8)3mm | |Adafruit Silicon (4x4)x4|24 |Psykhaze| | | |Adafruit Silicon 3mm 8x8 Matrix|24| |x(8x8)3mm | |Adafruit Silicon (4x4)x4|24 |Psykhaze| | | ||
- | |Joystick |25 |2xJoystick |2xRGB | | |8 | | | | + | |Sparkfun Silicon 5mm 4x4 RGB Matrix|25| |16xWS2812 | |Sparkfun Silicon 4x4|24|Latigid| | |
- | |Linear Touch |26 |1x(Force)Linear Sensor| 8xWS2812| | |8 |Psykhaze| | | + | |RGB Encoder 4x4 Matrix|26| | |RGB Encoders x16| |24 |Latigid | | |
- | |Circular touch|27 |1x(2x)Circular Sensor|16(x2)xWS2812| | |16 |Psykhaze| | | + | |Joystick |27 |2xJoystick |2xRGB | | |8 | | | |
- | |Force touch |28 |4xForce touch|4xRGB | | |8 | | | | + | |Linear Touch |28 |1x(Force)Linear Sensor| 8xWS2812| | |8 |Psykhaze| | |
- | |MiniDeck DJ Control|29|1xScratchFader+ 1xVertical Fader|x8 3mm|x1 Code Wheel +x3 PushRotary| |32| | | | + | |Circular touch|29 |1x(2x)Circular Sensor|16(x2)xWS2812| | |16 |Psykhaze| | |
+ | |Force touch |30 |4xForce touch|4xRGB | | |8 | | | | ||
+ | |MiniDeck DJ Control|31|1xScratchFader+ 1xVertical Fader|x8 3mm|x1 Code Wheel +x3 PushRotary| |32| | | | ||
===== Frontpanels Layouts ===== | ===== Frontpanels Layouts ===== | ||
- | {{neonking:modulbox-panels.jpg?direct&770|}} | + | {{:neonking:modulbox-panels.jpg?direct&730|}} |
- | {{neonking:modulbox-panels2.jpg?direct&780|}} | + | {{:neonking:modulbox-panels2.jpg?direct&770|}} |
- | {{neonking:modulbox-panels3.jpg?direct&790|}} | + | {{:neonking:modulbox-panels3.jpg?direct&870|}} |
