mb-modulbox-ng [2016/08/10 04:21] psykhaze [Modules List + UI Parts] |
mb-modulbox-ng [2016/08/15 00:46] psykhaze [MB-ModulBox NG] |
Line 3: | Line 3: | ||
{{ ::neonking:modulbox-logo.jpg?direct&600 |}} | {{ ::neonking:modulbox-logo.jpg?direct&600 |}} | ||
- | // <wrap info> Under Heavy Developpment @ **9/8/2016** </wrap>// | + | // <wrap info> Under Heavy Developpment @ **15/8/2016** </wrap>// |
Line 75: | Line 75: | ||
===== Tech Demos Videos ===== | ===== Tech Demos Videos ===== | ||
+ | {{youtube>ZqLzL6nxHbs?small}} | ||
{{youtube>utr23hp2nRM?small}} | {{youtube>utr23hp2nRM?small}} | ||
{{youtube>KQALHoqk4XA?small}} | {{youtube>KQALHoqk4XA?small}} | ||
Line 87: | Line 88: | ||
^ Module ^ N° ^ Analog ^ LED ^Encoders ^ Switches ^HP ^ User ^ Display^ | ^ Module ^ N° ^ Analog ^ LED ^Encoders ^ Switches ^HP ^ User ^ Display^ | ||
- | |Main UI+Main PCB|1 |Jacksx16 | |x1 PushRotary|Tactilex6 |24 |Psykhaze|Graphic-OLEDx1| | + | |Main UI+Main PCB|1 |Jacksx16 | |x1 PushRotary|Tactilex6 |24 |Psykhaze/Latigid|Graphic-OLEDx1| |
- | |Horizontal 4xOLEDS SCSE|2 | | |x1 PushRotary|Tactilex7 |24 | |Small-OLEDx4| | + | |OLED-SCS |2 | | |x1 PushRotary|Tactilex6 |24 |Latigid |Small-OLEDx1->8| |
- | |Vertical 4xOLEDS|3 | | | | |16 | |Small-OLEDx4 | | + | |Vertical 4xOLEDS|3 | | | | |16 |Latigid |Small-OLED x4 | |
|LCD Vertical SCS|4 | | |x1 PushRotary|Tactilex(4+4+2)|16| |CLCD 20x4| | |LCD Vertical SCS|4 | | |x1 PushRotary|Tactilex(4+4+2)|16| |CLCD 20x4| | ||
- | |LCD Horizontal SCSE|5 | | |x2 PushRotary|Tactilex22 |32 |Psykhaze|2xCLCD 40x4| | + | |LCD Horizontal Extended SCS|5 | | |x2 PushRotary|Tactilex22 |32 |Psykhaze|2xCLCD 40x4| |
|Encoders x8 |6 | | |x8 PushRotary| |8 | Ksir | | | |Encoders x8 |6 | | |x8 PushRotary| |8 | Ksir | | | ||
|Pots x8 |7 |Pots x8 | | | |8 | Ksir | | | |Pots x8 |7 |Pots x8 | | | |8 | Ksir | | | ||
Line 111: | Line 112: | ||
|Crosspoint Matrix 8x4(x4)|23|Jacksx(8+4)|x(8x4) 3mm | |Toggle 4poles, Tactilex(8+4)|16|Psykhaze| | | |Crosspoint Matrix 8x4(x4)|23|Jacksx(8+4)|x(8x4) 3mm | |Toggle 4poles, Tactilex(8+4)|16|Psykhaze| | | ||
|Adafruit Silicon 3mm 8x8 Matrix|24| |x(8x8)3mm | |Adafruit Silicon (4x4)x4|24 |Psykhaze| | | |Adafruit Silicon 3mm 8x8 Matrix|24| |x(8x8)3mm | |Adafruit Silicon (4x4)x4|24 |Psykhaze| | | ||
- | |Joystick |25 |2xJoystick |2xRGB | | |8 | | | | + | |Sparkfun Silicon 5mm 4x4 RGB Matrix|25| |16xWS2812 | |Sparkfun Silicon 4x4|24|Latigid| | |
- | |Linear Touch |26 |1x(Force)Linear Sensor| 8xWS2812| | |8 |Psykhaze| | | + | |RGB Encoder 4x4 Matrix|26| | |RGB Encoders x16| |24 |Latigid | | |
- | |Circular touch|27 |1x(2x)Circular Sensor|16(x2)xWS2812| | |16 |Psykhaze| | | + | |Joystick |27 |2xJoystick |2xRGB | | |8 | | | |
- | |Force touch |28 |4xForce touch|4xRGB | | |8 | | | | + | |Linear Touch |28 |1x(Force)Linear Sensor| 8xWS2812| | |8 |Psykhaze| | |
- | |MiniDeck DJ Control|29|1xScratchFader+ 1xVertical Fader|x8 3mm|x1 Code Wheel +x3 PushRotary| |32| | | | + | |Circular touch|29 |1x(2x)Circular Sensor|16(x2)xWS2812| | |16 |Psykhaze| | |
+ | |Force touch |30 |4xForce touch|4xRGB | | |8 | | | | ||
+ | |MiniDeck DJ Control|31|1xScratchFader+ 1xVertical Fader|x8 3mm|x1 Code Wheel +x3 PushRotary| |32| | | | ||
===== Frontpanels Layouts ===== | ===== Frontpanels Layouts ===== | ||
- | {{::neonking:modulbox-panels.jpg?direct&770|}} | + | {{:neonking:modulbox-panels.jpg?direct&730|}} |
- | {{::neonking:modulbox-panels2.jpg?direct&780|}} | + | {{:neonking:modulbox-panels2.jpg?direct&770|}} |
- | {{::neonking:modulbox-panels3.jpg?800 |}} | + | {{:neonking:modulbox-panels3.jpg?direct&870|}} |
Line 131: | Line 131: | ||
^ . ^ 1 ^ 2 ^ 3 ^ 4 ^ 5 ^ 6 ^ 7 ^ 8 ^ 9 ^ 10 ^ 11 ^ 12 ^ 13 ^ 14 ^ 15 ^ | ^ . ^ 1 ^ 2 ^ 3 ^ 4 ^ 5 ^ 6 ^ 7 ^ 8 ^ 9 ^ 10 ^ 11 ^ 12 ^ 13 ^ 14 ^ 15 ^ | ||
| Digital Ins |8 |0>16|/ |12 |30 |16 |/ |8 |/ |/ |/ |? |8 |24 |8 | | | Digital Ins |8 |0>16|/ |12 |30 |16 |/ |8 |/ |/ |/ |? |8 |24 |8 | | ||
+ | | 74HC165 # |1 |0>2|/ |2 |4 |2 |/ |1 |/ |/ |/ |? |1 |3 |1 | | ||
| Digital Outs |/ |/ |/ |/ |/ |/ |/ |16 |/ |/ |/ |16+?|/ |16 |8>16| | | Digital Outs |/ |/ |/ |/ |/ |/ |/ |16 |/ |/ |/ |16+?|/ |16 |8>16| | ||
+ | | 74HC595 # |/ |/ |/ |/ |/ |/ |/ |2 |/ |/ |/ |2+? |/ |2 |1>2 | | ||
| Analog Ins |/ |/ |/ |/ |/ |/ |16 |/ |8 |8 |4 |? |/ |/ |/ | | | Analog Ins |/ |/ |/ |/ |/ |/ |16 |/ |8 |8 |4 |? |/ |/ |/ | | ||
| CLCD # |/ |/ |/ |1 |2 |/ |/ |/ |/ |/ |/ |/ |/ |/ |/ | | | CLCD # |/ |/ |/ |1 |2 |/ |/ |/ |/ |/ |/ |/ |/ |/ |/ | | ||
Line 138: | Line 140: | ||
^ . ^ 16 ^ 17 ^ 18 ^ 19 ^ 20 ^ 21 ^ 22 ^ 23 ^ 24 ^ 25 ^ 26 ^ 27 ^ 28 ^ 29 ^ 30 ^ 31 ^ | ^ . ^ 16 ^ 17 ^ 18 ^ 19 ^ 20 ^ 21 ^ 22 ^ 23 ^ 24 ^ 25 ^ 26 ^ 27 ^ 28 ^ 29 ^ 30 ^ 31 ^ | ||
| Digital Ins |16 |4 |8 |16 |/ |/ |24 |15 |16 |16 |32 |/ |3 |/ |/ |12 | | | Digital Ins |16 |4 |8 |16 |/ |/ |24 |15 |16 |16 |32 |/ |3 |/ |/ |12 | | ||
+ | | 74HC165 # |2 |1 |1 |2 |/ |/ |3 |2 |2 |2 |4 |/ |1 |/ |/ |2 | | ||
| Digital Outs |8 |16 |32? |16 |16 |32 |/ |16 |16 |/ |/ |6 |/ |/ |12 |8 | | | Digital Outs |8 |16 |32? |16 |16 |32 |/ |16 |16 |/ |/ |6 |/ |/ |12 |8 | | ||
+ | | 74HC595 # |1 |2 |4 |2 |2 |4 |/ |2 |2 |/ |/ |1 |/ |/ |2 |1 | | ||
| Analog Ins |/ |/ |/ |/ |/ |/ |0>8 |/ |/ |/ |/ |8 |/ |3>6 |8 |8 | | | Analog Ins |/ |/ |/ |/ |/ |/ |0>8 |/ |/ |/ |/ |8 |/ |3>6 |8 |8 | | ||
| CLCD # |/ |/ |/ |/ |/ |/ |/ |/ |/ |/ |/ |/ |/ |/ |/ |/ | | | CLCD # |/ |/ |/ |/ |/ |/ |/ |/ |/ |/ |/ |/ |/ |/ |/ |/ | |
