This page is to describe the operation of the MB808 Sequencer application. It is a work in progress, comments are welcome and usually appreciated :)
Forum Thread: http://www.midibox.org/forum/index.php?topic=7391.0
This document is split into 3 sections:
This application is not meant to be part of a modular system or even a standalone box, it's origins are a simple adaptation of the MBSEQ v2.4 application to mimic to functionality of the original 808's digital section. As such the primary task for this application is to provide 13 editable tracks to cover the 12 instruments + accent data and to create the proper pulse signals for the inputs of the instruments. However, MBSEQ v2.4 is a very deep application and it would be a shame to ignore many it's features so the primary task is to create an interface using the available buttons and encoders that can access as many menu functions as possible, without making the whole thing obscure. Remember, this is a drummachine first, sequencer second :)
This is a list of planned features. Certian to be changed over time.
The MB808 application will essentially be unchanged from the SEQ v2.4 application. The changes that will be made reguard the interface, specifically the LCD screen and encoders will not be present. At this time I also think it is best to use TK's drummode for the operation of the sequencer. Although this prevents each step from having it's own flam value, what we gain is much more than what we loose. Firstly using drum mode gives us 12 instrument tracks + accent all in one pattern as opposed to re-working the handling of the pattern sets to allow the use of 12 complete tracks, this keeps things compatible with the base application and hopefully with the upcoming SEQv3 application :) Using drum mode also allows us to use the morph feature, but in a way that mimics the original 808. Each pattern can be linked to the same pattern in the lowercase bank switched between like with the “A+B” toggle switch on the original, my favorite feature. This will take a bit of trickery in code to keep things compatible, so it may not be implemented in the first version. The second big advantage I realized this morning while thinking about the Pro-1. It's sequencer was absolutely minimal, you just switched into edit mode and entered notes until the phrase was entered. No rests. The Pro-1 would then play it back, automatically looping it. I realized that with the extra tracks avaiable and using the arrpegiate mode along with the step edit mode the mb808 could also sequence basslines and trigger arrpegios! This is very cool!
There are 35 elements to the MB808 interface. They are:
NOTE: this is still a hypothetical interface. The changes reguarding V3 are not represented here and this is really just to show how the F buttons can be used as menu buttons to reduce dependancy on an LCD screen.
The MB808 application has 5 different modes that it can operate in, they are:
In each mode the 16 GP buttons have a different function and each mode has it's own set of menus accessed with the menu buttons. The operation of the 16 GP's for each mode and menu are described below
Pattern Play | ||||||||||||||||
GP# | GP1 | GP2 | GP3 | GP4 | GP5 | GP6 | GP7 | GP8 | GP9 | GP10 | GP11 | GP12 | GP13 | GP14 | GP15 | GP16 |
Default | Bank 1 | Bank 2 | Bank 3 | Bank 4 | Bank 5 | Bank 6 | Bank 7 | Bank 8 | Pattern 1 | Pattern 2 | Pattern 3 | Pattern 4 | Pattern 5 | Pattern 6 | Pattern 7 | Pattern 8 |
F2 | Forward | Backward | Ping Pong | Random | BPM / 1 | BPM / 2 | BPM / 4 | BPM / 8 | BPM / 16 | BPM / 32 | BPM / 64 |
Pattern Edit | ||||||||||||||||
Default | Step 1 | Step 2 | Step 3 | Step 4 | Step 5 | Step 6 | Step 7 | Step 8 | Step 9 | Step 10 | Step 11 | Step 12 | Step 13 | Step 14 | Step 15 | Step 16 |
F1 | BD | SD | LT/LC | MT/MC | HT/HC | CP | MA | RS/CL | CB | CY | OH | CH | Control 1 | Control 2 | Control 3 | Control 4 |
Song Play | ||||||||||||||||
Default | Song 1 | Song 2 | Song 3 | Song 4 | Song 5 | Song 6 | Song 7 | Song 8 | Song 9 | Song 10 | Song 11 | Song 12 | Song 13 | Song 14 | Song 15 | Song 16 |
F1 | Position 1 | Position 2 | Position 3 | Position 4 | Position 5 | Position 6 | Position 7 | Position 8 | Position 9 | Position 10 | Position 11 | Position 12 | Position 13 | Position 14 | Position 15 | Position 16 |
Song Edit | ||||||||||||||||
F2 | Part 1 | Part 2 | Part 3 | Part 4 | Part 5 | Part 6 | Part 7 | Part 8 |
Mute Play | ||||||||||||||||
Default | BD | SD | LT/LC | MT/MC | HT/HC | CP | MA | RS/CL | CB | CY | OH | CH | Control 1 | Control 2 | Control 3 | Control 4 |
F1 | Group 1 | Group 2 | Group 3 | Group 4 | Group 5 | Group 6 | Group 7 | Group 8 | Group 9 | Group 10 | Group 11 | Group 12 | Group 13 | Group 14 | Group 15 | Group 16 |
Global Functions | ||||||||||||||||
F3 | Bank 1 | Bank 2 | Bank 3 | Bank 4 | Bank 5 | Bank 6 | Bank 7 | Bank 8 | Pattern 1 | Pattern 2 | Pattern 3 | Pattern 4 | Pattern 5 | Pattern 6 | Pattern 7 | Pattern 8 |
F4 | Next bar | Next quart. | Next 8th | Next 16th | Clear Patt | Clear Track | Copy Track | Copy Patt | Paste | Save | MIDI | SysEx |
Button | Loop | Fwd | Rwd | Stop | Play | Tap | Ins. Select | Datawheel |
Pattern Play | Set loop points | Next MetaBank | Prev MetaBank | Stop | Play | Tap | Ins. Select | |
Pattern Edit | Set loop points | Next Bar | Prev Bar | Stop | Play | Audition | Ins Select | Meter |
Song Play | latch loop | Next Pos. | Prev Pos | Stop | Play | Tap | Ins. Select | |
Song Edit | Jump point | Next MetaBank | Prev MetaBank | Stop | Play | Tap | Ins. Select |
There are 3 main components to this modification:
The 808's instruments are all comprised of a combination of twin-t oscillators, a noise source and simple envelopes. Both the twin-t and the envelope take a breif pulse of varying amplitude to trigger and set the amplitude and each of the 808's instruments have a AND gate made up of 2 transistors to interface with the digital controller. These AND gates have inputs for 2 signals, called common trig and instrument data. Each instrument has it's own data line but there is only one common trig which is shared by all instruments. The common trig signal is active high for 1ms in synchronization with the master clock. Each instrument data signal is a 5v active high 1ms pulse which is only present when that instrument should be triggered. The AND gate insures that both signals are present before sounding an instrument. Creating the instrument data signal is easy using MB hardware, a DOUT pin does the job nicely. Altering the code to flash a DOUT pin on a note event is fairly simple as well. The common trig signal is a little more complicated. The accent data, which is a voltage between 5v and 15v is also represented in the common trig signal. As such it is the pulse present on the common trig input that triggers the instrument while the instrument data signal insures the instrument is only triggered at the rigt step. Luckily the accent signal only needs two states, on and off, where off is always 5v and on is a higher voltage determined by a potentiometer. Now, this could be solved by using a logiv switch like the 4016 or 4066, using a DOUT pin to toggle between connecting the common trig line to 5v or the wiper of the accent pot. However, looking over the schematics I've found an even simpler way that only needs a couple transistors. The concept is simple, we still use a pot connected as a voltage divider between the 5v and 15v rails to get our accent voltage but a simple transistor can be used to shunt the voltage of the wiper to the 5v rail when it is turned on. If we invert the common trig signal in code so that it is active low we only need the single transistor ;)
Now, in the original, the common trig pulsed on every clock tick. This isn't neccessary, instead the common trig line will only be pulsed when a note on occurs.
In order to get the most out of the SEQ application without using a datawheel or an LCD and without risking becoming incompatible with future versions I decided it was best to use the 4 function buttons as menu buttons to modify the action of the general purpose buttons. In order to do this I need to modify the code in each of the f buttons handlers. These can be found starting on line 681 of seq_buttons.inc. First I cleared out the code that was in there. Now, the simplest way to do this is to set a bit representing when one of the menu buttons is pressed. Since I want them all ro be momentary I can then simply clear the bit when the button is released.
