mb909 [2012/05/23 19:39] pcbatterij |
mb909 [2016/09/12 18:51] pcbatterij |
Line 1: | Line 1: | ||
====== <mb909> ====== | ====== <mb909> ====== | ||
- | kiCAD design of the board | ||
- | {{http://users.telenet.be/MB909/Sequencer/MB909IIIsmall.jpg}} | ||
Home made prototype, finishing now 14th of February 2012 (and it works!!!) | Home made prototype, finishing now 14th of February 2012 (and it works!!!) | ||
Line 23: | Line 20: | ||
The MB909 control surface is using the LPC core and altered SeqV4 firmware. | The MB909 control surface is using the LPC core and altered SeqV4 firmware. | ||
+ | currently the sequencer has 2 MIDI IN and 2 MIDI OUT, but this is expandable to 4 IN and 4 OUT. The current LPC core board does not have the extra MIDI's on board. | ||
+ | A three digit led display shows the BPM like on the original TR-909. The BPM is controlled with an encoder. | ||
+ | A nice dogm graphical display is used as LCD | ||
The patterns can be for example 32 steps long with 3 trigger layers (gate, accent, roll, ....) and 2 parameter layers(velocity, roll, roll2, ...) | The patterns can be for example 32 steps long with 3 trigger layers (gate, accent, roll, ....) and 2 parameter layers(velocity, roll, roll2, ...) | ||
In edit screen: | In edit screen: | ||
- | * pushing one of the 16 general purpose buttons sets the selected step to normal velocity, pushing it again sets the selected step to accented. | + | * pushing one of the 16 general purpose buttons sets the selected step to normal velocity and the led will be orange, pushing it again sets the selected step to accented and the led will be red. |
Line 76: | Line 78: | ||
List of pots, buttons, faders and blah - suggestions on good parts and where to buy them + how to hook them up - links | List of pots, buttons, faders and blah - suggestions on good parts and where to buy them + how to hook them up - links | ||
+ | components | ||
+ | 1uF (cer 10%) 9 810-FK14X5R1C105K | ||
+ | 100nF (cer 20%) 14 Z5U-2,5 100N | ||
+ | 100pF (cer 5mm) 4 KERKO-500 100P | ||
+ | 100R 4 METALL 100 | ||
+ | 100uF 1 RAD 100/16; 140-REA101M1CBK0611P | ||
+ | 10K 1% 1 METALL 10,0K | ||
+ | SIL5 res 10K 6 SIL 5-4 10K | ||
+ | SIL6 res 10K 6 SIL 6-5 10K | ||
+ | R pack 220R 7 652-4116R-1LF-220 | ||
+ | 47R 1 METALL 47,0 | ||
+ | 74HC165 6 74HC 165 | ||
+ | 74HC595 8 74HC 595 | ||
+ | 7 segment X3 1 604-BC56-12SRWA | ||
+ | conn 1 row 1 SL 1X36G 2,54 | ||
+ | conn 2 rows 1 SL 2X17G 2,54 | ||
+ | DUO LED 2X5 16 LED 2 RG-3 | ||
+ | encoder cap BL 3 450-BA600 | ||
+ | encoder 3 688-EC12E24204A9 | ||
+ | IC socket 16pin 14 GS 16 | ||
+ | seq led 3mm red 16 LED 3MM 2MA RT | ||
+ | Cherry cap beige 12 DSA 1X BEIGE GCF RECESSED MOUNT | ||
+ | Cherry cap white 6 DSA 1X WHITE WFK RECESSED MOUNT | ||
+ | LCD display 1 790-EADOGM128W6 | ||
+ | LCD back red 1 790-EALED55X46R | ||
+ | Cherry switch 18 540-MX1A-11NW | ||
+ | tact cap white 22 653-B32-1260 | ||
+ | tact switch 22 653-B3F-4055 | ||
+ | PCB boards | ||
+ | MB909 beta PCB 1 MB909 beta PCB | ||
[[:home:mbhp:parts | Where to buy Parts]] | [[:home:mbhp:parts | Where to buy Parts]] | ||
Line 85: | Line 120: | ||
===== Enclosure / Case ===== | ===== Enclosure / Case ===== | ||
- | Enclosure ideas - link to case construction tips? / provide space to encourage other users to wikify their case designs | + | The enclosure will be a nice acrylic frontpanel with matching case. |
+ | {{http://www.synthage.com/images/front prototype.jpg}} | ||
==== Enclosure References ==== | ==== Enclosure References ==== |
