mb_olre16 [2016/09/23 19:59] psykhaze [Core-External Driving Concept : TLC5958] |
mb_olre16 [2019/04/21 08:50] antichambre [GrayScale Clock] |
Line 30: | Line 30: | ||
We expect 16 RGB LED rings encoders. So let's do the math : | We expect 16 RGB LED rings encoders. So let's do the math : | ||
**16 Encoders * 32 LEDs * 3 colors = __1536 lines__ ** \\ | **16 Encoders * 32 LEDs * 3 colors = __1536 lines__ ** \\ | ||
- | Let's transpose this to a classical matrixed SRIO chain design: | + | Let's transpose this to a classical matrixed SRIO chain design: \\ |
- | **3x16=48 inputs + 32 outputs = __6*DIN + 4*DOUT__ **\\ | + | ** 16 * 3 (cathodes) * 32 (anodes)** \\ |
+ | **= 48 inputs + 32 outputs ** \\ | ||
+ | **= __6*DIN + 4*DOUT__ **\\ | ||
==== Core-External Driving Concept : TLC5958 ==== | ==== Core-External Driving Concept : TLC5958 ==== | ||
- | In theory it's possible to drive such a SRIO setup but in fact buses and resistors/R networs are very hard to place and will consume a lot of process. \\ | + | In theory it's possible to drive such a SRIO setup but in fact buses and resistors/R networks are very hard to place and it will consume a lot of contant refresh process. \\ |
After a look on the different brands and models of LED driver IC **[[http://www.ti.com/product/TLC5958|Texas Instruments TLC5958]]** appeared as a good compromise to drive a lot of RGB LEDs without overloading the core. Designed to be a LED Display driver, its original purpose and features would allow large-sized RGB-LED-based display setups\\ | After a look on the different brands and models of LED driver IC **[[http://www.ti.com/product/TLC5958|Texas Instruments TLC5958]]** appeared as a good compromise to drive a lot of RGB LEDs without overloading the core. Designed to be a LED Display driver, its original purpose and features would allow large-sized RGB-LED-based display setups\\ | ||
Line 100: | Line 101: | ||
==== Data Transfer ==== | ==== Data Transfer ==== | ||
- | A serialized design has been chosen to provide data to TLC. Prototype feature only 2 steps but the CORE works like there's 4 modules of 16 steps connected. In order to benchmark reactivity and Transfer time, Core send data for 4 modules. Through an emulated software SPI bus, for this 64 rings Data Sending __takes less than 5ms__ . Different colors and patterns like relative value(-64/63), keyboard(B&W keys) etc... were tested.\\ | + | A serialized design has been chosen to provide data to TLC. Prototype feature only 2 steps but the CORE works like there's 4 modules of 16 steps connected. In order to benchmark reactivity and Transfer time, Core send data for 4 modules(4*16*32*3*16bit=12KBytes). Through an emulated software SPI bus, for this 64 rings Data Sending __takes less than 5ms__ . Different colors and patterns like relative value(-64/63), keyboard(B&W keys) etc... were tested.\\ |
{{antichambre:img_3658.jpg?300|}}{{:antichambre:img_3657.jpg?300|}}{{antichambre:img_3656.jpg?300|}}\\ | {{antichambre:img_3658.jpg?300|}}{{:antichambre:img_3657.jpg?300|}}{{antichambre:img_3656.jpg?300|}}\\ | ||
{{antichambre:large.img_3754.jpg?300|}} {{:antichambre:large.3653bd.jpeg?460|}}\\ | {{antichambre:large.img_3754.jpg?300|}} {{:antichambre:large.3653bd.jpeg?460|}}\\ | ||
==== GrayScale Clock ==== | ==== GrayScale Clock ==== | ||
Line 126: | Line 126: | ||
{{:antichambre:slva645_5_2.png?800|}}\\ | {{:antichambre:slva645_5_2.png?800|}}\\ | ||
- | TLC is wired like on an SPI bus to Core Board. Here are equivalences:\\ | + | TLC is wired like on an SPI bus to Core Board. Here are connections equivalences:\\ |
* SCLK => SC | * SCLK => SC | ||
* DATA => SO | * DATA => SO | ||
* LAT => RC | * LAT => RC | ||
* FLAGS READ => SI | * FLAGS READ => SI | ||
+ | **[[stm32f4_module#inputs_outputs_ports|STM32F4 I/O Ports]]** | ||
//Note: Command is coded by putting LAT active during a defined number of SCLK periods.For example for a VSYNC command, LAT must be high during 3 SCLK pulses.//\\ | //Note: Command is coded by putting LAT active during a defined number of SCLK periods.For example for a VSYNC command, LAT must be high during 3 SCLK pulses.//\\ | ||
Line 138: | Line 140: | ||
**Frame update is needed only when a change occurs, TLC keep all the frame in memory and continue to distribute it to the 32 addresses lines and 16 rgb leds by address ** | **Frame update is needed only when a change occurs, TLC keep all the frame in memory and continue to distribute it to the 32 addresses lines and 16 rgb leds by address ** | ||
Line 143: | Line 146: | ||
The TLC needs a GrayScale Clock(GSCLK) and additional control to multiplex 32 addresses (named COMSELx in diagram). The GSCLK signal should be 257 pulses + 1.5~2.5µs of interval between segments . COMSEL management needs 32 multiplexing adress lines for (5 bits coded and decoded directly on the top board).\\ | The TLC needs a GrayScale Clock(GSCLK) and additional control to multiplex 32 addresses (named COMSELx in diagram). The GSCLK signal should be 257 pulses + 1.5~2.5µs of interval between segments . COMSEL management needs 32 multiplexing adress lines for (5 bits coded and decoded directly on the top board).\\ | ||
- | === Clock Schematic === | + | === Clock Schematic version 1 === |
+ | <wrap center round important 60%> | ||
+ | //Note: This circuit is replaced by a simulated one, on a CPLD.// | ||
+ | </wrap> | ||
{{:antichambre:tlc_gsclk.png?800|}}\\ | {{:antichambre:tlc_gsclk.png?800|}}\\ | ||
Line 152: | Line 159: | ||
CORE provides a regular Clock with PWM @2MHz .The 12bit counter U16 counts until 257 and trigs U1 wich is a monostable, U1 switchs, resets the counter and stops the clock counter input by U17(D-Flipflop). \\ | CORE provides a regular Clock with PWM @2MHz .The 12bit counter U16 counts until 257 and trigs U1 wich is a monostable, U1 switchs, resets the counter and stops the clock counter input by U17(D-Flipflop). \\ | ||
- | After a certain time given by the RC couple on U1, U1 switch back and restarts the counter. | + | After a certain time given by the RC couple on U1, U1 switchs back and restarts the counter. |
By this way we are sure to count the exact 257 Clocks needed and the interval between 2 segments is fixed by the trimpot U19.\\ | By this way we are sure to count the exact 257 Clocks needed and the interval between 2 segments is fixed by the trimpot U19.\\ | ||
Line 159: | Line 166: | ||
=== Multiplexing Schematic === | === Multiplexing Schematic === | ||
- | {{:antichambre:tlc_gsclk_topb.png?800|}}\\ | + | {{:antichambre:tlc_gsclk_topb.png?500|}}\\ |
ADDR_x, ADDR_CLK, GSCLK are connected to the top board...\\ | ADDR_x, ADDR_CLK, GSCLK are connected to the top board...\\ | ||
Line 165: | Line 172: | ||
ADDR_CLK is the multiplexed lines clock . It's used to gate the PWM signal and obtain the GSCLK and of course, as a clock for the ADDR Counter U5. The counter U5 provides the coded ADDR_x lines and an EOF(End Of Frame) when 32 is reached.\\ | ADDR_CLK is the multiplexed lines clock . It's used to gate the PWM signal and obtain the GSCLK and of course, as a clock for the ADDR Counter U5. The counter U5 provides the coded ADDR_x lines and an EOF(End Of Frame) when 32 is reached.\\ | ||
+ | === Clock version 2 === | ||
+ | <wrap center round todo 60%> | ||
+ | CPLD/FPGA version | ||
+ | </wrap> | ||
