mb_rgb-led_matrix_8x8 [2014/08/04 18:18] ilmenator [BOM] |
mb_rgb-led_matrix_8x8 [2014/08/04 18:25] ilmenator [BOM] added images of different LED modules |
Line 33: | Line 33: | ||
- | An additional 5V power connector (P3) is not necessary. | + | An additional 5V power connector (P3) is not necessary. The RGB LED matrix modules can be found in various variants, e.g. with round or square LEDs. They should follow the {{:home:users:ilmenator:rgb-led:hl-m2388brgb.pdf|specifications defined in this document}}. |
+ | {{:home:users:ilmenator:rgb-led:midibox_rgb-led_matrix_8x8_v1.3_06.jpg?305|}} {{:home:users:ilmenator:rgb-led:midibox_rgb-led_matrix_8x8_v1.3_05.jpg?300|}} |
