mb_rgb-led_matrix_8x8
Differences
Link to this comparison view
Both sides previous revision Previous revision
Last revision Both sides next revision
mb_rgb-led_matrix_8x8 [2014/08/04 18:23]
ilmenator [BOM] added link to RGB LED module datasheet
mb_rgb-led_matrix_8x8 [2014/08/04 18:25]
ilmenator [BOM] added images of different LED modules
Line 34: Line 34:
 An additional 5V power connector (P3) is not necessary. The RGB LED matrix modules can be found in various variants, e.g. with round or square LEDs. They should follow the {{:​home:​users:​ilmenator:​rgb-led:​hl-m2388brgb.pdf|specifications defined in this document}}. An additional 5V power connector (P3) is not necessary. The RGB LED matrix modules can be found in various variants, e.g. with round or square LEDs. They should follow the {{:​home:​users:​ilmenator:​rgb-led:​hl-m2388brgb.pdf|specifications defined in this document}}.
 +{{:​home:​users:​ilmenator:​rgb-led:​midibox_rgb-led_matrix_8x8_v1.3_06.jpg?​305|}} {{:​home:​users:​ilmenator:​rgb-led:​midibox_rgb-led_matrix_8x8_v1.3_05.jpg?​300|}}
mb_rgb-led_matrix_8x8.txt ยท Last modified: 2014/08/04 18:33 by ilmenator
