mb_visual_metronome [2013/05/23 18:40] gomiboy99 [Master Unit Design] |
mb_visual_metronome [2016/06/14 11:54] psykhaze |
Line 1: | Line 1: | ||
====== Visual Metronome ====== | ====== Visual Metronome ====== | ||
Line 6: | Line 5: | ||
At a recent show, there was a problem with the monitors leaving the rest of the band unable to hear the beat. \\ | At a recent show, there was a problem with the monitors leaving the rest of the band unable to hear the beat. \\ | ||
We normally use a click track but it was not possible at this show. This lead me to come up with this design for a visual metronome so the others know where we are in the bar. | We normally use a click track but it was not possible at this show. This lead me to come up with this design for a visual metronome so the others know where we are in the bar. | ||
+ | {{:gomiboy99:vm_slave.jpg?500}} | ||
I posted my original design in the forum, the reply from technobreath inspired me to redesign the project. \\ | I posted my original design in the forum, the reply from technobreath inspired me to redesign the project. \\ | ||
The project is now in 2 parts, a master unit and a slave. The master can be used as a midi clock master and a standalone midi & visual metronome. \\ | The project is now in 2 parts, a master unit and a slave. The master can be used as a midi clock master and a standalone midi & visual metronome. \\ | ||
The slave can be used with the master or with a sequencer or with your DAW's metronome output.\\ | The slave can be used with the master or with a sequencer or with your DAW's metronome output.\\ | ||
+ | Version 02 has 32 preset memory locations to store the setup for quick recall.\\ | ||
The master hardware consists of \\ | The master hardware consists of \\ | ||
Line 16: | Line 19: | ||
* DOUTx2 | * DOUTx2 | ||
* 20x2 CLCD (HD44780) | * 20x2 CLCD (HD44780) | ||
- | * 3 buttons and 1 encoder on the control surface | + | * 5 buttons and 1 encoder on the control surface |
* LEDs to suit the hardware options | * LEDs to suit the hardware options | ||
Line 34: | Line 37: | ||
An explanation of the menu/display is {{:gomiboy99:vm_display_v02.pdf|here}}\\ | An explanation of the menu/display is {{:gomiboy99:vm_display_v02.pdf|here}}\\ | ||
- | The source code is available {{:gomiboy99:visual_metronome_v0_2.zip|here}} | + | The source code is available {{:gomiboy99:visual_metronome_v02_1.zip|here}} |
+ | Here are some pictures of the master unit that I have built. The board is a home made version of the pic core along with a custom DOUTx2 DINx1 board. I had intended to separate the 2 boards but the whole panel fitted in the case so left them as one. I left several components out of the core part, only the parts required for this project are fitted. The unit is powered by a 5volt SMPS. | ||
+ | {{:gomiboy99:imag0557_1.jpg?100|}} {{:gomiboy99:imag0558.jpg?100|}} {{:gomiboy99:imag0560.jpg?100|}} | ||
===== Slave Unit Design ===== | ===== Slave Unit Design ===== | ||
Line 61: | Line 66: | ||
Here is what my version looks like inside | Here is what my version looks like inside | ||
- | {{:gomiboy99:vm_slave.jpg?400}} | + |
