Both sides previous revision Previous revision | |||
mbhp4066 [2010/05/28 21:02] lemonhorse |
mbhp4066 [2010/05/28 21:07] (current) lemonhorse |
Line 5: | Line 5: | ||
In my case I needed more than 100 of them! | In my case I needed more than 100 of them! | ||
- | For that reason I created the **MBHP_4066** board. | + | For that reason (and with the engaged support of **nILS** and **PCB Mike**) the **MBHP_4066** board was created. |
One MBHP_4066 board provides 16 bilateral switches. | One MBHP_4066 board provides 16 bilateral switches. | ||
- | For more Information have a look of the pdf file below. | + | For more Information have a look at the pdf file below. |
- | Thanks for the engaged support **nILS** and **PCB Mike**! | ||
Line 29: | Line 29: | ||
* **MBHP_4066** with remarks and a Partlist ==> [[http://www.subfrequenz.net/midibox/vss200/mbhp4066v1/MBHP4066V1.pdf]] | * **MBHP_4066** with remarks and a Partlist ==> [[http://www.subfrequenz.net/midibox/vss200/mbhp4066v1/MBHP4066V1.pdf]] | ||
- | * Mike will provide the MBHP_4066 board in his Onlineshop ==> [[http://www.mikes-elektronikseite.de/mshop_englisch/|http://www.mikes-elektronikseite.de/mshop_englisch/ ]] | + | * PCB Mike will provide the MBHP_4066 board in his Onlineshop |
* 4066 Datasheet (found no better source yet) ==> [[http://pdf1.alldatasheet.com/datasheet-pdf/view/8175/NSC/4066.html]] | * 4066 Datasheet (found no better source yet) ==> [[http://pdf1.alldatasheet.com/datasheet-pdf/view/8175/NSC/4066.html]] |
