Next revision | Previous revision Last revision Both sides next revision | ||
mbhp4066 [2010/05/28 20:39] lemonhorse created |
mbhp4066 [2010/05/28 21:02] lemonhorse |
Line 2: | Line 2: | ||
For MIDIfying old analog Sound gear You'll need bilateral switches in some cases. | For MIDIfying old analog Sound gear You'll need bilateral switches in some cases. | ||
- | In my case I needed more than 100 of them. | + | |
+ | In my case I needed more than 100 of them! | ||
For that reason I created the **MBHP_4066** board. | For that reason I created the **MBHP_4066** board. | ||
- | Thank You for the engaged support nILS and PCB Mike! | + | |
+ | One MBHP_4066 board provides 16 bilateral switches. | ||
+ | For more Information have a look of the pdf file below. | ||
+ | Thanks for the engaged support **nILS** and **PCB Mike**! | ||
{{http://www.subfrequenz.net/midibox/vss200/mbhp4066v1/MBHP4066V1.jpg}} | {{http://www.subfrequenz.net/midibox/vss200/mbhp4066v1/MBHP4066V1.jpg}} | ||
+ | The MBHP_4066 Board (assembled) | ||
{{http://www.subfrequenz.net/midibox/vss200/mbhp4066v1/MBHP4066V1BRDsmal.jpg}} | {{http://www.subfrequenz.net/midibox/vss200/mbhp4066v1/MBHP4066V1BRDsmal.jpg}} | ||
+ | The MBHP_4066 Board (PCB, Eagle) | ||
- | ====== Overview and Details of the MBHP_4066 Board ====== | ||
- | * Information about the MBHP_4066 V1 board ==> [[http://www.subfrequenz.net/midibox/vss200/mbhp4066v1/MBHP4066V1.pdf]] | + | **Overview and Details:** |
+ | * **MBHP_4066** with remarks and a Partlist ==> [[http://www.subfrequenz.net/midibox/vss200/mbhp4066v1/MBHP4066V1.pdf]] | ||
+ | * Mike will provide the MBHP_4066 board in his Onlineshop ==> [[http://www.mikes-elektronikseite.de/mshop_englisch/|http://www.mikes-elektronikseite.de/mshop_englisch/ ]] | ||
* 4066 Datasheet (found no better source yet) ==> [[http://pdf1.alldatasheet.com/datasheet-pdf/view/8175/NSC/4066.html]] | * 4066 Datasheet (found no better source yet) ==> [[http://pdf1.alldatasheet.com/datasheet-pdf/view/8175/NSC/4066.html]] | ||
