Both sides previous revision Previous revision | Next revision Both sides next revision | ||
mbhp4066 [2010/05/28 20:51] lemonhorse |
mbhp4066 [2010/05/28 20:57] lemonhorse |
Line 11: | Line 11: | ||
{{http://www.subfrequenz.net/midibox/vss200/mbhp4066v1/MBHP4066V1.jpg}} | {{http://www.subfrequenz.net/midibox/vss200/mbhp4066v1/MBHP4066V1.jpg}} | ||
- | The MBHP_4066 Board | + | |
+ | The MBHP_4066 Board (assembled) | ||
{{http://www.subfrequenz.net/midibox/vss200/mbhp4066v1/MBHP4066V1BRDsmal.jpg}} | {{http://www.subfrequenz.net/midibox/vss200/mbhp4066v1/MBHP4066V1BRDsmal.jpg}} | ||
+ | The MBHP_4066 Board (PCB, Eagle View) | ||
====== Overview and Details of the MBHP_4066 Board ====== | ====== Overview and Details of the MBHP_4066 Board ====== | ||
- | * Information about the MBHP_4066 V1 board ==> [[http://www.subfrequenz.net/midibox/vss200/mbhp4066v1/MBHP4066V1.pdf]] | + | * **MBHP_4066** comments with the Partlist ==> [[http://www.subfrequenz.net/midibox/vss200/mbhp4066v1/MBHP4066V1.pdf]] |
* Mike will provide the MBHP_4066 board in his Onlineshop ==> [[http://www.mikes-elektronikseite.de/mshop_englisch/|http://www.mikes-elektronikseite.de/mshop_englisch/ ]] | * Mike will provide the MBHP_4066 board in his Onlineshop ==> [[http://www.mikes-elektronikseite.de/mshop_englisch/|http://www.mikes-elektronikseite.de/mshop_englisch/ ]] | ||
* 4066 Datasheet (found no better source yet) ==> [[http://pdf1.alldatasheet.com/datasheet-pdf/view/8175/NSC/4066.html]] | * 4066 Datasheet (found no better source yet) ==> [[http://pdf1.alldatasheet.com/datasheet-pdf/view/8175/NSC/4066.html]] | ||
