mbqg_fp [2017/08/13 15:00] sauraen |
mbqg_fp [2024/02/02 15:01] smithy [MIDIbox Quad Genesis: Front Panel] |
Line 1: | Line 1: | ||
====== MIDIbox Quad Genesis: Front Panel ====== | ====== MIDIbox Quad Genesis: Front Panel ====== | ||
+ | {{http://midibox.org/forums/uploads/monthly_2017_09/59c6a64298b45_Frontpanelfull.jpg.22d95b55e3ada643ee3aa6933f0d9753.jpg?640}} | ||
To build the front panel of MIDIbox Quad Genesis, you will need (details on each part below): | To build the front panel of MIDIbox Quad Genesis, you will need (details on each part below): | ||
- | * An aluminum front panel | + | * An aluminum front panel **OR** PCB Front Panel from Smithy ([[http://midibox.org/forums/topic/19678-midibox-quad-genesis/?do=findComment&comment=200872|See forum post]]) **OR** 3D Printed Front Panel (See Below) |
* A PCB to hold all the buttons, LEDs, encoders, etc., and of course all these electronic components themselves | * A PCB to hold all the buttons, LEDs, encoders, etc., and of course all these electronic components themselves | ||
* A bunch of 3D printed transparent button caps | * A bunch of 3D printed transparent button caps | ||
Line 14: | Line 16: | ||
=== Dimensions === | === Dimensions === | ||
- | The aluminum (or acrylic) front panel of MIDIbox Quad Genesis is 15" x 11" (38.1 x 27.9 cm), and the front panel PCB itself is 13.85" x 9.85" (35.18 x 25.02 cm), leaving a 0.57" (1.45 cm) border around the edge. The aluminum I used was 1/16" (0.062" or 1.57 mm); this may be a consideration if you use acrylic which is much thicker (2mm should probably be fine but 3mm might be a problem, with the 3D printed buttons). | + | The aluminum (or acrylic) front panel of MIDIbox Quad Genesis is 15" x 11" (38.1 x 27.9 cm), and the front panel PCB itself is 13.85" x 9.85" (35.18 x 25.02 cm), leaving a 0.57" (1.45 cm) border around the edge. The aluminum I used was 1/16" (0.062" or 1.57 mm); this may be a consideration if you use acrylic which is much thicker (2mm should probably be fine but 3mm might be a problem, with the 3D printed buttons - **Update** - Smithy has provided modified files for 3D printed buttons and light pipes to fit 3mm panels below. ). |
The spacing between the underside of the front panel and the upper side of the PCB is about 0.27" (7 mm), which is originally defined by the encoders and the 3D printed buttons are made to match this. I used 1/4" nylon spacers/standoffs from eBay plus a flat washer (4-40 or M3) to achieve this spacing. I used 0.75" 4-40 screws to put together the front panel, in which case the depth of the assembly was 0.75" with the electrolytic capacitors and pin header / IDC connector sticking out past this. The panel and PCB can be fastened together with 4-40 or M3 screws. | The spacing between the underside of the front panel and the upper side of the PCB is about 0.27" (7 mm), which is originally defined by the encoders and the 3D printed buttons are made to match this. I used 1/4" nylon spacers/standoffs from eBay plus a flat washer (4-40 or M3) to achieve this spacing. I used 0.75" 4-40 screws to put together the front panel, in which case the depth of the assembly was 0.75" with the electrolytic capacitors and pin header / IDC connector sticking out past this. The panel and PCB can be fastened together with 4-40 or M3 screws. | ||
Line 34: | Line 36: | ||
[[http://midibox.org/forums/applications/core/interface/file/attachment.php?id=13216|mbqg_fp_modledrings.fpd]] | [[http://midibox.org/forums/applications/core/interface/file/attachment.php?id=13216|mbqg_fp_modledrings.fpd]] | ||
+ | ===== 3D Printed Front Panel ===== | ||
+ | Smithy has provided an STL file for a 2mm 3D Printed Front Panel with 1mm Raised Lettering as a more budget friendly option. It will require a printer with a bed side size typically of 400 x 400mm or larger. | ||
+ | This is currently untested and unprinted, and may require a resolution / layer height setting of 0.1mm to be accurate. More info to come when I have designed and 3D printed and a Rear Panel. | ||
+ | Please see the following guide to achieve a dual colour panel with a different colour for the lettering and for the panel: | ||
+ | [[http://midibox.org/forums/topic/21751-how-to-3d-print-bi-coloured-panels-and-cases-included-raised-lettering/?tab=comments#comment-188241|Forum Link]] | ||
+ | ==== Download ==== | ||
+ | [[http://midibox.org/forums/applications/core/interface/file/attachment.php?id=15446|mbqg_fp_modledrings_Holes_Moved_ready_to_print.zip]] | ||
===== MBQG_FP PCB ===== | ===== MBQG_FP PCB ===== | ||
Line 42: | Line 54: | ||
Front: | Front: | ||
- | [[http://midibox.org/forums/gallery/image/3232-midibox-quad-genesis-front-panel-mbqg_fp-pcb-front/|{{http://midibox.org/forums/uploads/monthly_2017_01/large.frontpanel_bareboard_front.jpg.d56b036ea546506ee649a8b1b95afebb.jpg?800}}]] | + | [[http://midibox.org/forums/gallery/image/3232-midibox-quad-genesis-front-panel-mbqg_fp-pcb-front/|{{http://midibox.org/forums/uploads/monthly_2017_01/large.frontpanel_bareboard_front.jpg.a46a203426766cd49714af08444ae840.jpg?800}}]] |
Back: | Back: | ||
- | [[http://midibox.org/forums/gallery/image/3231-midibox-quad-genesis-front-panel-mbqg_fp-pcb-back/|{{http://midibox.org/forums/uploads/monthly_2017_01/large.frontpanel_bareboard_back.jpg.b00646e4566ee7eca42b1d579d5b5355.jpg?800}}]] | + | [[http://midibox.org/forums/gallery/image/3231-midibox-quad-genesis-front-panel-mbqg_fp-pcb-back/|{{http://midibox.org/forums/uploads/monthly_2017_01/large.frontpanel_bareboard_back.jpg.ae7676c6fb15707ec1f1afe8afd38c04.jpg?800}}]] |
Populated and with almost all LEDs lit: | Populated and with almost all LEDs lit: | ||
- | [[http://midibox.org/forums/gallery/image/3230-midibox-quad-genesis-front-panel-mbqg_fp-pcb-most-leds-on/|{{http://midibox.org/forums/uploads/monthly_2017_01/large.frontpanel_allleds.jpg.7ef408bbe1653a850567ab324e648ca6.jpg?800}}]] | + | [[http://midibox.org/forums/gallery/image/3230-midibox-quad-genesis-front-panel-mbqg_fp-pcb-most-leds-on/|{{http://midibox.org/forums/uploads/monthly_2017_01/large.frontpanel_allleds.jpg.f32ae66e3e7ee70a14e850670c2cb573.jpg?800}}]] |
Line 71: | Line 83: | ||
| Red LEDs for lighting buttons/caps (4500mcd (!)) | 604-WP710A10SRC/J4 | 87 | | | Red LEDs for lighting buttons/caps (4500mcd (!)) | 604-WP710A10SRC/J4 | 87 | | ||
| Orange LEDs for lighting buttons/caps (2700mcd (!)) | 604-WP710A10SEC | 9 | | | Orange LEDs for lighting buttons/caps (2700mcd (!)) | 604-WP710A10SEC | 9 | | ||
- | | Yellow LEDs for lighting buttons/caps (3200mcd (!)) | 859-LTL17KYV3JS | 24 | | + | | Yellow LEDs for lighting buttons/caps (3200mcd (!)) | 859-LTL17KYV3JS | 18 | |
- | | Green LEDs for lighting buttons/caps (7200mcd (!)) | 859-LTL17KTGX3KS | 74 | | + | | Green LEDs for lighting buttons/caps (7200mcd (!)) | 859-LTL17KTGX3KS | 76 | |
| Blue LEDs for lighting buttons/caps (1500mcd (!)) | 859-LTL17KTBS3KS | 220 | | | Blue LEDs for lighting buttons/caps (1500mcd (!)) | 859-LTL17KTBS3KS | 220 | | ||
| Red LEDs for panel indication (i.e. sticking through holes in front panel) (Tinted, Diffused) | 604-WP710A10SRD/D | 26 | | | Red LEDs for panel indication (i.e. sticking through holes in front panel) (Tinted, Diffused) | 604-WP710A10SRD/D | 26 | | ||
Line 99: | Line 111: | ||
Schematic image (unfortunately, MIDIbox Gallery scaled down the original image, and offsite documentation is frowned upon): [[http://midibox.org/forums/uploads/monthly_2017_02/large.MBQG_FP_rendered.gif.cbe871b269f4c4758577c366cc628b44.gif|{{http://midibox.org/forums/uploads/monthly_2017_02/large.MBQG_FP_rendered.gif.cbe871b269f4c4758577c366cc628b44.gif?800}}]] | Schematic image (unfortunately, MIDIbox Gallery scaled down the original image, and offsite documentation is frowned upon): [[http://midibox.org/forums/uploads/monthly_2017_02/large.MBQG_FP_rendered.gif.cbe871b269f4c4758577c366cc628b44.gif|{{http://midibox.org/forums/uploads/monthly_2017_02/large.MBQG_FP_rendered.gif.cbe871b269f4c4758577c366cc628b44.gif?800}}]] | ||
- | Front panel KiCad project coming soon! | ||
For Color fields, as discussed above, you may change the colors to whatever you want, but it is recommended to keep the colors consistent (e.g. make everything "green" below be the same color, and everything "red" below be a different color). For the Red/Green buttons below, the Red LED is always on the left and the Green LED is always on the right. | For Color fields, as discussed above, you may change the colors to whatever you want, but it is recommended to keep the colors consistent (e.g. make everything "green" below be the same color, and everything "red" below be a different color). For the Red/Green buttons below, the Red LED is always on the left and the Green LED is always on the right. | ||
Line 197: | Line 207: | ||
| LD32 | LED | Red | FM Widget Feedback | | | LD32 | LED | Red | FM Widget Feedback | | ||
| LD41, LD43,\\ LD47, LD50 | LED | Yellow | Key On | | | LD41, LD43,\\ LD47, LD50 | LED | Yellow | Key On | | ||
+ | | LD52--LD53,\\ LD58-LD59, \\ LD60-LD64, \\ | LED | Green | System Load Meter | | ||
+ | | LD54, LD57,\\ LD65-LD66, | LED | Yellow | System Load Meter | | ||
+ | | LD55-LD56,\\ LD67 | LED | Red | System Load Meter | | ||
| R1--R2 | Resistors | N/A | 2.2k terminating resistors for clock and latch lines | | | R1--R2 | Resistors | N/A | 2.2k terminating resistors for clock and latch lines | | ||
| RP0--RP1 | Resistor Packs | N/A | 1k row driver pull-ups (to reduce ghosting) | | | RP0--RP1 | Resistor Packs | N/A | 1k row driver pull-ups (to reduce ghosting) | | ||
Line 434: | Line 447: | ||
==== Things You Should Know If Having These Printed ==== | ==== Things You Should Know If Having These Printed ==== | ||
* You need 115 buttons and 26 LED pipes, assuming you're not using LED pipes for all the LED rings. However, especially if the 3D printer (machine and/or person) is inexperienced, you will need lots of extras. For the LED pipes, because they are friction-fit, buy at least double the number you will need; and for the buttons, at least 20 extra or so. | * You need 115 buttons and 26 LED pipes, assuming you're not using LED pipes for all the LED rings. However, especially if the 3D printer (machine and/or person) is inexperienced, you will need lots of extras. For the LED pipes, because they are friction-fit, buy at least double the number you will need; and for the buttons, at least 20 extra or so. | ||
- | * The total cost to have these items printed should be roughly $20-$30 plus shipping. If someone is trying to charge you more than that, either there's an issue (like they got the scale wrong and think you want giant-sized parts), or they're trying to gyp you. | + | * The total cost to have these items printed should be roughly $20-$30 plus shipping. If someone is trying to charge you more than that, either there's an issue (like they got the scale wrong and think you want giant-sized parts), or they're trying to gyp you. **If you try to get these printed by a commercial service (e.g. Ponoko), they will charge a minimum of $1 per part and the result will be prohibitively expensive!** Have them printed by a real person instead, either a friend with a 3D printer or possibly someone from the RepRap forums. |
==== Things You Need to Tell the Person Printing Them ==== | ==== Things You Need to Tell the Person Printing Them ==== | ||
- | * The scale in the STL files is 1 INCH, not 1 mm. The buttons should be about 1/2" or 12mm wide. (This is not intended as an engineering dimension, just as a sanity check--use the actual dimensions in the file.) | + | * The scale in the STL files is 1 INCH, not 1 mm. The buttons should be about 1/2" or 12mm wide. (This is not intended as an engineering dimension, just as a sanity check--use the actual dimensions in the file.) |
+ | * **Update:** Smithy has added additional STL files in metric scale below. | ||
* Either ABS or PLA transparent filament should work. I had the guy who made them for me do tests with both, and I liked the light-up appearance of the ABS better but the "off" appearance of the PLA better. But they were pretty similar. | * Either ABS or PLA transparent filament should work. I had the guy who made them for me do tests with both, and I liked the light-up appearance of the ABS better but the "off" appearance of the PLA better. But they were pretty similar. | ||
* I had the guy who made them for me do tests with different fill rates, and if I remember correctly around 10% fill worked best. 100% fill would be needlessly expensive and would dim the LEDs. | * I had the guy who made them for me do tests with different fill rates, and if I remember correctly around 10% fill worked best. 100% fill would be needlessly expensive and would dim the LEDs. | ||
Line 449: | Line 462: | ||
[[http://midibox.org/forums/applications/core/interface/file/attachment.php?id=13219|mbqg_fp_ledpipes.stl]] | [[http://midibox.org/forums/applications/core/interface/file/attachment.php?id=13219|mbqg_fp_ledpipes.stl]] | ||
+ | Additional files provided by Smithy: | ||
+ | [[http://midibox.org/forums/applications/core/interface/file/attachment.php?id=15442|Buttons in metric scale for 2mm Front Panel]] | ||
+ | [[http://midibox.org/forums/applications/core/interface/file/attachment.php?id=15443|LED pipes in metric scale for 2mm Front Panel]] | ||
+ | [[http://midibox.org/forums/applications/core/interface/file/attachment.php?id=15444|Buttons in metric scale for 3mm Front Panel]] | ||
+ | [[http://midibox.org/forums/applications/core/interface/file/attachment.php?id=15445|LED pipes in metric scale for 3mm Front Panel]] | ||
