mbqg_fp [2017/09/23 18:22] sauraen |
mbqg_fp [2017/09/23 18:25] sauraen [Schematic and Reference Designators] |
Line 73: | Line 73: | ||
| Red LEDs for lighting buttons/caps (4500mcd (!)) | 604-WP710A10SRC/J4 | 87 | | | Red LEDs for lighting buttons/caps (4500mcd (!)) | 604-WP710A10SRC/J4 | 87 | | ||
| Orange LEDs for lighting buttons/caps (2700mcd (!)) | 604-WP710A10SEC | 9 | | | Orange LEDs for lighting buttons/caps (2700mcd (!)) | 604-WP710A10SEC | 9 | | ||
- | | Yellow LEDs for lighting buttons/caps (3200mcd (!)) | 859-LTL17KYV3JS | 24 | | + | | Yellow LEDs for lighting buttons/caps (3200mcd (!)) | 859-LTL17KYV3JS | 18 | |
- | | Green LEDs for lighting buttons/caps (7200mcd (!)) | 859-LTL17KTGX3KS | 74 | | + | | Green LEDs for lighting buttons/caps (7200mcd (!)) | 859-LTL17KTGX3KS | 76 | |
| Blue LEDs for lighting buttons/caps (1500mcd (!)) | 859-LTL17KTBS3KS | 220 | | | Blue LEDs for lighting buttons/caps (1500mcd (!)) | 859-LTL17KTBS3KS | 220 | | ||
| Red LEDs for panel indication (i.e. sticking through holes in front panel) (Tinted, Diffused) | 604-WP710A10SRD/D | 26 | | | Red LEDs for panel indication (i.e. sticking through holes in front panel) (Tinted, Diffused) | 604-WP710A10SRD/D | 26 | | ||
Line 101: | Line 101: | ||
Schematic image (unfortunately, MIDIbox Gallery scaled down the original image, and offsite documentation is frowned upon): [[http://midibox.org/forums/uploads/monthly_2017_02/large.MBQG_FP_rendered.gif.cbe871b269f4c4758577c366cc628b44.gif|{{http://midibox.org/forums/uploads/monthly_2017_02/large.MBQG_FP_rendered.gif.cbe871b269f4c4758577c366cc628b44.gif?800}}]] | Schematic image (unfortunately, MIDIbox Gallery scaled down the original image, and offsite documentation is frowned upon): [[http://midibox.org/forums/uploads/monthly_2017_02/large.MBQG_FP_rendered.gif.cbe871b269f4c4758577c366cc628b44.gif|{{http://midibox.org/forums/uploads/monthly_2017_02/large.MBQG_FP_rendered.gif.cbe871b269f4c4758577c366cc628b44.gif?800}}]] | ||
- | Front panel KiCad project coming soon! | ||
For Color fields, as discussed above, you may change the colors to whatever you want, but it is recommended to keep the colors consistent (e.g. make everything "green" below be the same color, and everything "red" below be a different color). For the Red/Green buttons below, the Red LED is always on the left and the Green LED is always on the right. | For Color fields, as discussed above, you may change the colors to whatever you want, but it is recommended to keep the colors consistent (e.g. make everything "green" below be the same color, and everything "red" below be a different color). For the Red/Green buttons below, the Red LED is always on the left and the Green LED is always on the right. |
