mbqg_fp
Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision
Previous revision
Next revision Both sides next revision
mbqg_fp [2017/09/23 18:24]
sauraen [Parts List for MBQG_FP PCB]
mbqg_fp [2021/01/29 20:16]
smithy [Photos] bad links
Line 44: Line 44:
 Front: Front:
-[[http://​midibox.org/​forums/​gallery/​image/​3232-midibox-quad-genesis-front-panel-mbqg_fp-pcb-front/​|{{http://​midibox.org/​forums/​uploads/​monthly_2017_01/​large.frontpanel_bareboard_front.jpg.d56b036ea546506ee649a8b1b95afebb.jpg?​800}}]]+[[http://​midibox.org/​forums/​gallery/​image/​3232-midibox-quad-genesis-front-panel-mbqg_fp-pcb-front/​|{{http://​midibox.org/​forums/​uploads/​monthly_2017_01/​large.frontpanel_bareboard_front.jpg.a46a203426766cd49714af08444ae840.jpg?​800}}]]
 Back: Back:
-[[http://​midibox.org/​forums/​gallery/​image/​3231-midibox-quad-genesis-front-panel-mbqg_fp-pcb-back/​|{{http://​midibox.org/​forums/​uploads/​monthly_2017_01/​large.frontpanel_bareboard_back.jpg.b00646e4566ee7eca42b1d579d5b5355.jpg?​800}}]]+[[http://​midibox.org/​forums/​gallery/​image/​3231-midibox-quad-genesis-front-panel-mbqg_fp-pcb-back/​|{{http://​midibox.org/​forums/​uploads/​monthly_2017_01/​large.frontpanel_bareboard_back.jpg.ae7676c6fb15707ec1f1afe8afd38c04.jpg?​800}}]]
 Populated and with almost all LEDs lit: Populated and with almost all LEDs lit:
-[[http://​midibox.org/​forums/​gallery/​image/​3230-midibox-quad-genesis-front-panel-mbqg_fp-pcb-most-leds-on/​|{{http://​midibox.org/​forums/​uploads/​monthly_2017_01/​large.frontpanel_allleds.jpg.7ef408bbe1653a850567ab324e648ca6.jpg?​800}}]]+[[http://​midibox.org/​forums/​gallery/​image/​3230-midibox-quad-genesis-front-panel-mbqg_fp-pcb-most-leds-on/​|{{http://​midibox.org/​forums/​uploads/​monthly_2017_01/​large.frontpanel_allleds.jpg.f32ae66e3e7ee70a14e850670c2cb573.jpg?​800}}]]
Line 101: Line 101:
 Schematic image (unfortunately,​ MIDIbox Gallery scaled down the original image, and offsite documentation is frowned upon): [[http://​midibox.org/​forums/​uploads/​monthly_2017_02/​large.MBQG_FP_rendered.gif.cbe871b269f4c4758577c366cc628b44.gif|{{http://​midibox.org/​forums/​uploads/​monthly_2017_02/​large.MBQG_FP_rendered.gif.cbe871b269f4c4758577c366cc628b44.gif?​800}}]] Schematic image (unfortunately,​ MIDIbox Gallery scaled down the original image, and offsite documentation is frowned upon): [[http://​midibox.org/​forums/​uploads/​monthly_2017_02/​large.MBQG_FP_rendered.gif.cbe871b269f4c4758577c366cc628b44.gif|{{http://​midibox.org/​forums/​uploads/​monthly_2017_02/​large.MBQG_FP_rendered.gif.cbe871b269f4c4758577c366cc628b44.gif?​800}}]]
-Front panel KiCad project coming soon!
 For Color fields, as discussed above, you may change the colors to whatever you want, but it is recommended to keep the colors consistent (e.g. make everything "​green"​ below be the same color, and everything "​red"​ below be a different color). For the Red/Green buttons below, the Red LED is always on the left and the Green LED is always on the right. For Color fields, as discussed above, you may change the colors to whatever you want, but it is recommended to keep the colors consistent (e.g. make everything "​green"​ below be the same color, and everything "​red"​ below be a different color). For the Red/Green buttons below, the Red LED is always on the left and the Green LED is always on the right.
Line 199: Line 197:
 | LD32 | LED | Red | FM Widget Feedback | | LD32 | LED | Red | FM Widget Feedback |
 | LD41, LD43,\\ LD47, LD50 | LED | Yellow | Key On | | LD41, LD43,\\ LD47, LD50 | LED | Yellow | Key On |
 +| LD52--LD53,​\\ LD58-LD59, \\ LD60-LD64, \\  | LED | Green | System Load Meter |
 +| LD54, LD57,\\ LD65-LD66, | LED | Yellow | System Load Meter |
 +| LD55-LD56,​\\ LD67 | LED | Red | System Load Meter |
 | R1--R2 | Resistors | N/A | 2.2k terminating resistors for clock and latch lines | | R1--R2 | Resistors | N/A | 2.2k terminating resistors for clock and latch lines |
 | RP0--RP1 | Resistor Packs | N/A | 1k row driver pull-ups (to reduce ghosting) | | RP0--RP1 | Resistor Packs | N/A | 1k row driver pull-ups (to reduce ghosting) |
mbqg_fp.txt ยท Last modified: 2024/02/02 15:01 by smithy
