mbqg_fp [2017/09/23 18:25] sauraen [Schematic and Reference Designators] |
mbqg_fp [2021/01/29 20:16] smithy [Photos] bad links |
Line 44: | Line 44: | ||
Front: | Front: | ||
- | [[http://midibox.org/forums/gallery/image/3232-midibox-quad-genesis-front-panel-mbqg_fp-pcb-front/|{{http://midibox.org/forums/uploads/monthly_2017_01/large.frontpanel_bareboard_front.jpg.d56b036ea546506ee649a8b1b95afebb.jpg?800}}]] | + | [[http://midibox.org/forums/gallery/image/3232-midibox-quad-genesis-front-panel-mbqg_fp-pcb-front/|{{http://midibox.org/forums/uploads/monthly_2017_01/large.frontpanel_bareboard_front.jpg.a46a203426766cd49714af08444ae840.jpg?800}}]] |
Back: | Back: | ||
- | [[http://midibox.org/forums/gallery/image/3231-midibox-quad-genesis-front-panel-mbqg_fp-pcb-back/|{{http://midibox.org/forums/uploads/monthly_2017_01/large.frontpanel_bareboard_back.jpg.b00646e4566ee7eca42b1d579d5b5355.jpg?800}}]] | + | [[http://midibox.org/forums/gallery/image/3231-midibox-quad-genesis-front-panel-mbqg_fp-pcb-back/|{{http://midibox.org/forums/uploads/monthly_2017_01/large.frontpanel_bareboard_back.jpg.ae7676c6fb15707ec1f1afe8afd38c04.jpg?800}}]] |
Populated and with almost all LEDs lit: | Populated and with almost all LEDs lit: | ||
- | [[http://midibox.org/forums/gallery/image/3230-midibox-quad-genesis-front-panel-mbqg_fp-pcb-most-leds-on/|{{http://midibox.org/forums/uploads/monthly_2017_01/large.frontpanel_allleds.jpg.7ef408bbe1653a850567ab324e648ca6.jpg?800}}]] | + | [[http://midibox.org/forums/gallery/image/3230-midibox-quad-genesis-front-panel-mbqg_fp-pcb-most-leds-on/|{{http://midibox.org/forums/uploads/monthly_2017_01/large.frontpanel_allleds.jpg.f32ae66e3e7ee70a14e850670c2cb573.jpg?800}}]] |
Line 197: | Line 197: | ||
| LD32 | LED | Red | FM Widget Feedback | | | LD32 | LED | Red | FM Widget Feedback | | ||
| LD41, LD43,\\ LD47, LD50 | LED | Yellow | Key On | | | LD41, LD43,\\ LD47, LD50 | LED | Yellow | Key On | | ||
+ | | LD52--LD53,\\ LD58-LD59, \\ LD60-LD64, \\ | LED | Green | System Load Meter | | ||
+ | | LD54, LD57,\\ LD65-LD66, | LED | Yellow | System Load Meter | | ||
+ | | LD55-LD56,\\ LD67 | LED | Red | System Load Meter | | ||
| R1--R2 | Resistors | N/A | 2.2k terminating resistors for clock and latch lines | | | R1--R2 | Resistors | N/A | 2.2k terminating resistors for clock and latch lines | | ||
| RP0--RP1 | Resistor Packs | N/A | 1k row driver pull-ups (to reduce ghosting) | | | RP0--RP1 | Resistor Packs | N/A | 1k row driver pull-ups (to reduce ghosting) | |
