MIDIbox Quad Genesis Case designed by Technobreath
The case is designed by Technobreath to be easily replicated by the community without requiring much skills or tools.
Here you will find a pdf with dimensions and building instructions for a wooden case designed for the MIDIbox Quad Genesis by user Technobreath:
Please see this forum post in the Quad Genesis Build Guide Thread for further step by step instructions on how to build the case: http://midibox.org/forums/topic/20619-build-guide-midibox-quad-genesis/?do=findComment&comment=180084
Huge thanks to Technobreath for taking the time to design this case!
You will need 8 threaded inserts with an internal diameter of 3mm for use with Smithy's PCB Front panel You can find these m3 threaded inserts with an external diameter of 5mm commonly on [[https://a.aliexpress.com/_ExA45x3]AliExpress]
