Both sides previous revision Previous revision | Next revision Both sides next revision | ||
midibox_3396 [2011/11/30 02:23] smashtv old revision restored (spam kill) |
midibox_3396 [2016/06/14 11:44] psykhaze |
Line 1: | Line 1: | ||
====== MIDIbox 3396 ====== | ====== MIDIbox 3396 ====== | ||
+ | **// :!: Project on Early Akpha Design Stage :!: //** | ||
This is a page for collecting ideas on how to build a synth based on the Curtis Electromusic Specialties CEM3396 IC chip, controlled via PIC of course. This chip is for example used in the Oberheim Matrix-1000 synth. It is out of production, but can be found at [[http://search.ebay.com/search/search.dll?from=R40&satitle=cem3396|ebay]] from time to time. | This is a page for collecting ideas on how to build a synth based on the Curtis Electromusic Specialties CEM3396 IC chip, controlled via PIC of course. This chip is for example used in the Oberheim Matrix-1000 synth. It is out of production, but can be found at [[http://search.ebay.com/search/search.dll?from=R40&satitle=cem3396|ebay]] from time to time. | ||
===== Data Sheet of CEM3396 ===== | ===== Data Sheet of CEM3396 ===== | ||
First please take a look at the {{:3396:cem3396_datasheet.pdf|CEM3396 datasheet}}. | First please take a look at the {{:3396:cem3396_datasheet.pdf|CEM3396 datasheet}}. | ||
===== Additional info, a readily available source of CEM 3396 chips: ===== | ===== Additional info, a readily available source of CEM 3396 chips: ===== |
