midibox_ay_3_8912_envelope [2009/06/20 16:58] 89.27.206.238 |
midibox_ay_3_8912_envelope [2011/05/13 17:44] lemonhorse |
Line 1: | Line 1: | ||
- | ===== MIDIBox AY 3 8912 - ENVELOPE FEATURES ===== | + | ===== MIDIBox AY V1 - Envelope ===== |
+ | === MIDIBox AY - Envelope Control Menu === | ||
- | === MIDIBox AY 3 8912 - ENVELOPE USER MENU === | + | * Just press **F5** to have a look at the MIDIBox AY ENVelope options (@ the MIDIBox AY Envelope User Menu). |
- | * PRESS **F5** TO VIEW ENVELOPE USER MENU OPTIONS | + | :: |
- | |EP COARSE|0 to 255| | + | === MIDIBox AY - Envelope Mode: ON/Off === |
- | |EP FINE|0 to 255| | + | |
- | |ENV.SHAPE|0 to 15| | + | |**Adjust**|**On or Off**| |
- | |ENV.TOGGLE|A B C| | + | |ENV. Mode |Tone A, B or C | |
+ | * Ttoggle **Envelope Mode** ON or OFF @ Tone [A, B or C] by using the C64 Keyboard keys A, B or C. | ||
+ | * Note: if the **Envelope Mode** is **ON** it will be indicated @ the **User Volume Control Menu** | ||
+ | * => For further Information have a look at the MIDIBox AY Volume Control Menu => [[midibox_ay_3_8912_volume]] | ||
+ | * => Information on MIDIBox AY (Envelope Mode ON/OFF) MIDI-Controller (CC) => [[midibox_ay_3_8912_cc_list]] | ||
- | === ENVELOPE ON/OFF TONE A, B and C: === | + | : |
- | * Menu item: ENV.TOGGLE: [A, B, C] | + | |
- | * Toggle the ENVELOPE MODE for TONE A, B or C via Key A, B or C | + | === MIDIBox AY - Envelope Period Control === |
- | * There will be **ENV.ON** @ Tone A or B or C on the **User Volume Control Menu** instead of the **volume value** if the **ENVELOPE MODE** is activated. | + | |
- | * For Midi Controller see => [[midibox_ay_3_8912_cc_list]] | + | The AY 3 8912 Chip provide two 8Bit **Envelope period** Control Register. |
+ | * Envelope Period FINE : [0 to 255] (bit 0-7 ) | ||
+ | * Envelope Period COARSE: [0 to 255] (bit 8-15) | ||
+ | Press [+] or [-] for increase or decrease the Envelope Period Value. | ||
+ | |**Adjust**|**Value**| | ||
+ | |ENV. Period Coarse |0 to 255| | ||
+ | |ENV. Perios Fine |0 to 255| | ||
+ | * => Information on MIDIBox AY (Envelope Period) MIDI-Controller (CC) => [[midibox_ay_3_8912_cc_list]] | ||
Line 31: | Line 51: | ||
- | + | === MIDIBox AY - Envelope Shape === | |
- | === ENVELOPE PERIOD CONTROL: === | + | |
- | The AY 3 8912 Chip provide a 16bit Envelope period Control. | + | |
- | * Menu item: EP COASE: [0 to 255] (bit 8-15) | + | |
- | * Menu item: EP FINE : [0 to 255] (bit 0-7 ) | + | |
- | Press [+] or [-] for increase or decrease the **E**nvelope **P**eriod value | + | |
{{http://www.subfrequenz.net/visuals/albums/userpics/mbay38912envnote2008.jpeg}} | {{http://www.subfrequenz.net/visuals/albums/userpics/mbay38912envnote2008.jpeg}} | ||
+ | [my homemade visualization of the the ENVELOPE SHAPE DOWN [1]] | ||
+ | **Envelope SHAPE: [0 to 8]** | ||
+ | * Press [+] or [-] | ||
+ | * [1] ENVELOPE SHAPE down | ||
+ | * [2] ENVELOPE SHAPE up down | ||
+ | * [3] ENVELOPE SHAPE down continue | ||
+ | * [4] ENVELOPE SHAPE down continue2 | ||
+ | * [5] ENVELOPE SHAPE down up | ||
+ | * [6] ENVELOPE SHAPE up continue | ||
+ | * [7] ENVELOPE SHAPE up | ||
+ | * [8] ENVELOPE SHAPE up continue2 | ||
+ | |ENV. SHAPE |1 to 8| | ||
+ | * => Information on MIDIBox AY (Envelope Shape) MIDI-Controller (CC) => [[midibox_ay_3_8912_cc_list]] | ||
Line 44: | Line 80: | ||
- | === ENVELOPE SHAPE CONTROL: === | + | |
- | * Menu item: ENV.SHAPE: [0 to 15] | + | === MIDIBox AY - Envelope Shape CS LED Interconnection === |
- | Press [+] or [-] | + | |
+ | {{:8912:mbay38912doutledenvelopev1.jpeg|}} | ||
- | {{http://www.subfrequenz.net/visuals/albums/userpics/MBAY38912ENV.jpg}} | ||
- | LCD VIEW: SHAPE [ **C** <del>ontinue</del>| **At** <del>tack</del> | **Al** <del>ternate</del>| **H** <del>old</del>] [0 to 15] | + | All MIDIBox AY CS LEDs See ⇒ [[midibox_ay_cs_led]] |
Line 63: | Line 96: | ||
- | [Date: 03.09.2008] | + | [Date: 03/2010] |
