midibox_ay_3_8912_mixer
−Table of Contents
MIDIBox AY 3 8912 Mixer
Notes:
- Pot R4 (Volume Tone A), R5 (Volume Tone B) and R6 (Volume Tone C) are designed for volume finetuning (not for turning off tone A/B/C)
Pot Options:
- R4, R5, R6 = 100k (less volume)
- R4, R5, R6 = 220k (more volume)
OP: LM324N (4xOP, +/-12V) - Datasheet:
- ⇒ LM324N.pdf /
Download: Eagle 5.1 Files + Partlist - MIDIBox AY 3 8912 Mixer (Ver.1a)
MASTER VOLUME POT
No OP MIXER Option
Notice: “You can easily leave out the opamp buffer board for testing. Just connect all three outputs via 10k resistors and add a pulldown of 1k-5k from that signal to ground.” (nILS Podewski, 2008-10-02)
PCB
The AY 3 8912 PCB and the AY 3 8912 OP-Mixer PCB are now available at Mikes Onlineshop
http://www.mikes-elektronikseite.de/shop_englisch/index.htm
[26.09.2008]
[07.10.2008]
midibox_ay_3_8912_mixer.1225050030.txt.gz · Last modified: 2008/10/26 19:40 (external edit)
