midibox_ay_3_8912_volume
MIDIBox AY 3 8912 - VOLUME MENU
* Press F4 (F3 + SHIFT) FOR THE USER VOLUME MENU
| TONE | VALUE | VELOCITY | ENVELOPE MODE |
| priority 3 | priority 2 | priority 1 | |
| VOLUME CH. A | 0 to 15 | ON/OFF | ON/OFF |
| VOLUME CH. B | 0 to 15 | ON/OFF | ON/OFF |
| VOLUME CH. C | 0 to 15 | ON/OFF | ON/OFF |
ENVELOPE TO TONE ABC ON/OFF (ENVELOPE MODE ON)
There will be [ENV.ON] @ Tone A or B or C on the User Volume Control Menu instead of the volume value if the ENVELOPE MODE is activated. If the Envelope Mode is in force the Volume Value will be overwritten. For more Information about the ENVELOPE MODE see ⇒ ENVELOPE (MENU)
VELOCITY TO TONE ABC ON/OFF (VELOCITY MODE ON)
The same here: if the VELOCITY to Tone A, B or C is activated the Volume Value will be overwritten. Note: if VELOCITY + ENVELOPE Mode is activated the Envelope Mode is in effect.
midibox_ay_3_8912_volume.1227016356.txt.gz · Last modified: 2008/11/18 13:52 by lemonhorse
