midibox_ay_3_8912_volume
MIDIBox AY 3 8912 - VOLUME MENU
MIDIBox AY 8912 Volume Respectively Amplitude Control:
* Press F4 (F3 + SHIFT) FOR THE USER VOLUME MENU
TONEUSER VALUECC7(A)/CC8(B)/CC9(C) MIDI VALUEVELOCITYENVELOPE MODE
priority 4priority 3priority 2priority 1
VOLUME CH. A0 to 150 to 127 ⇒ coversation to 0-15ON/OFFON/OFF
VOLUME CH. B0 to 150 to 127 ⇒ coversation to 0-15ON/OFFON/OFF
VOLUME CH. C0 to 150 to 127 ⇒ coversation to 0-15ON/OFFON/OFF
VOLUME CH. ABC - USER VALUE
Just adjust the USER VOLUME VALUE here.
CONTROL CHANGE 7,8 and 9 (MIDI CC EVENTS)
A CC7 (VOLUME A), CC8 (VOLUME B) and CC9 (VOLUME C) MIDI event overwrites the USER VOLUME VALUE (0-15) directly. But the CC Value will only apply if the VELOCITY and the ENVELOPE mode is off.
The MIDIBox AY 3 8912 CC LIST ⇒ MIDIBox_AY_3_8912_CC_LIST
ENVELOPE TO TONE ABC ON/OFF (ENVELOPE MODE ON)
There will be a [ENV.ON] @ Tone A or B or C on the User Volume Control Menu instead of the volume value if the ENVELOPE MODE is activated. If the ENVELOPE MODE is in force the Volume Value will be overwritten. For more Information about the ENVELOPE MODE see ⇒ ENVELOPE (MENU)
VELOCITY TO TONE ABC ON/OFF (VELOCITY MODE ON)
If the VELOCITY MODE is activated there will be a [VELOCITY] @ Tone A, B or C on the User Volume Control Menu instead of the volume value. In this case the Volume Value will be overwritten by the VELOCITY Value. Note: if VELOCITY + ENVELOPE Mode is activated the ENVELOPE MODE is in effect.
MANUAL VOLUME CONTROL
See ⇒ midibox_ay_3_8912_mixer
[18.11.2008]
midibox_ay_3_8912_volume.1227018794.txt.gz · Last modified: 2008/11/18 14:33 by lemonhorse
