**MIDIBox CV**\\ a MIDI-to-control voltage converter project =====MBHP Hardware Requirements===== 1 CORE module, 1 analog output module (AOUT, AOUT_LC, or AOUT_NG), 1 DINX1 module. Recommended: LCD, BankStick. =====Documentation===== * [[http://www.ucapps.de/midibox_cv.html|MIDIbox CV]] <sup>uCApps</sup> =====Links===== * [[How to use MIDIbox CV with a dout]] * [[How to use MIDIbox CV with a dout GERMAN]] * [[http://www.midibox.org/forum/index.php?topic=10412.msg78685#msg78685|How to use an encoder and up/down buttons on the same MIDIbox CV]] <sup>Forum</sup> =====Proposals for additional functions in future firmware versions===== (Please add your ideas here:) * One Page Up, one Page Down button should replace the Select button for faster selection of CV output * variable pulselength of gate outs depending on velocity * Use individual CV-Outs for dynamic (eg velocity dependant) triggers or gates * Adress note on to different trigger outs, depending on "velocity zones", eg to turn on accent or glide by velocity * Save different settings * "Rotate" note assignment in Poly mode (select "four voices" for example, then outputs 1-4 will rotate, advancing always with the next note. "Random" would also be nice.) * Vibrato LFO. Freerunning LFO summed into oscillator frequency output, amount controlled by Mod Wheel, amount= zero to a user-selected maximum. In addition to existing note/pitch wheel summing.
