See http://midibox.org/forums/topic/19073-midibox-fm-v21-on-stm32f4/ and http://midibox.org/forums/topic/18282-midibox-fm-v20-on-lpc17/
This is a synth by Sauraen constructed in 2014-2015. It's as finished as it ever will be, but it was never documented for others to try to replicate… until now!
Please note that this is still not a complete, well-documented project, and certainly not for beginners. I do not guarantee that all the information you will need is available here. Please comment on the MIDIbox FM V2.1 thread to ask for more information when necessary.
(Information from http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fmodules%2Fopl3%2FReadme.txt)
The OPL3's Reset line must be buffered to 5 volts; all the other inputs may be driven by 3.3 volts. Pinout:
The pins used for RS and the two CS pins may be changed by defining the appropriate things in your mios32_config.h file. See the README from the OPL3 module above. (Or just use the MIDIbox FM V2.1 code and hook the wires up as shown here.)
