midibox_lc
Differences
Link to this comparison view
Both sides previous revision Previous revision
midibox_lc [2011/09/17 17:04]
dougster
midibox_lc [2016/08/05 17:58]
192.243.55.130 ↷ Links adapted because of a move operation
Line 10: Line 10:
   * 3x DOUTX4 module for LED rings and LEDs    * 3x DOUTX4 module for LED rings and LEDs
   * 1x LTC module   * 1x LTC module
-  * 1x [[MF module]] if Motorfaders are to be used.  ​+  * 1x [[mf_ng_module]] if Motorfaders are to be used.  ​
     If not "in main.asm, you have to set "​ENABLE_MOTORDRIVER"​ to 0, this disables the motor control."​ as per TK [[http://​www.midibox.org/​forum/​index.php?​topic=5262.0|here]]     If not "in main.asm, you have to set "​ENABLE_MOTORDRIVER"​ to 0, this disables the motor control."​ as per TK [[http://​www.midibox.org/​forum/​index.php?​topic=5262.0|here]]
midibox_lc.txt · Last modified: 2016/08/05 17:58 by 192.243.55.130
