Detailed info for options and functions is available at http://www.ucapps.de/midibox_seq_manual_m.html
# | Function | Description / Options |
Dedicated button functions (theese can vary depending on panel design and MBSEQ_HW.V4 file) | ||
1 | Pattern 1,2,3,4 | Select pattern/track group - G1, G2, G3, G4 |
2 | Track 1,2,3,4 | Select track within track group - T1, T2, T3, T4 (16 tracks are available in total) |
3 | Trigger layer A,B,C | Select trigger layer A or B or C. Holding C opens trigger layer selection menu and allows to select others | Gate | Acc | Roll | Glide | Skip | R.G(random gate) | R.V(random value) | No FX | |
4 | Parameter layer A,B,C | Select parameter layer A and B. C switches between C & D or if Pressed&Hold opens parameter layer selection menu and allows to select others. Four parameter layers available by default, but CC, Pitch, Prob, Delay can be added via trigger selection menu (?) | Note | Vel | Length | Roll | |
5 | Step View | View and select steps if more than 16 are used | 1..16 | 17..32 | ...etc |
6 | Pattern | Select/load pattern/track group G1, G2, G3, G4 from SD memory location |
7 | Song | Select song parameters | Song # | Position | Action(Stop; x1..x16; Jump Pos; Jump Song; Mixer; Tempo; Mutes) || Select patterns G1,G2,G3,G4 | |
8 | Edit | Enter edit mode to edit parameter layer step values and set trigger layer steps |
9 | Mute | Quickly mute/unmute tracks 1…16 |
10 | Solo | Solo current track |
11 | ←/→ (Left/Right) | Move cursor position (Left has limited usage) |
4 | a | b |
