midibox_seq_quick_reference
MB SEQ functions - quick reference
Detailed info for options and functions is available at http://www.ucapps.de/midibox_seq_manual_m.html
| # | Function | Description / Options | ||||||||||||
| Dedicated button functions (theese can vary depending on panel design and MBSEQ_HW.V4 file) | ||||||||||||||
| 1 | Pattern 1,2,3,4 | Select pattern/track group - G1, G2, G3, G4 | ||||||||||||
| 2 | Track 1,2,3,4 | Select track within track group - T1, T2, T3, T4. 16 tracks are available in total | ||||||||||||
| 3 | Trigger layer A,B,C | Select trigger layer A or B or C. Holding C opens trigger layer selection menu and allows to select others <html> | Gate | Acc | Roll | Glide | Skip | R.G(random gate) | R.V(random value) | No FX | </html> | |||
| 4 | Parameter layer A,B,C | Select parameter layer A and B. C switches between C & D or with Pressed&Hold open parameter layer selection menu and allows to select others. Four parameter layers available by default, but CC, Pitch, Prob, Delay can be added via trigger selection menu (?) <html> | Note | Vel | Length | Roll | </html> | |||||||
| 5 | Step View | View and select steps if more than 16 are used <html> | 1..16 | 17..32 | …etc</html> | |||||||||
| 6 | Pattern | Select/load pattern/track group G1, G2, G3, G4 from SD memory location | ||||||||||||
| 7 | Song | Select song parameters <html> | Song # | Position | Action{Stop; x1..x16; Jump Pos; Jump Song; Mixer; Tempo; Mutes} | Select patterns: G1,G2,G3,G4 | </html> | |||||||
| 8 | Edit | Enter edit mode to edit parameter layer step values and set trigger layer steps | ||||||||||||
| 9 | Mute | Quickly mute/unmute tracks 1…16 | ||||||||||||
| 10 | Solo | Solo current track | ||||||||||||
| 11 | ←/→ (Left/Right) | Move cursor position. Left has limited usage | ||||||||||||
| 12 | +/- (Inc/Dec) | Same as Jog Dial encoder - increases/decreases the current value | ||||||||||||
| 13 | Exit | Quickly exit to top menu | ||||||||||||
| 14 | Select | (Press&Hold) Select steps to be controlled by All function. Obviously has usage in other situations as well (which?) | ||||||||||||
| 15 | All | Edit all selected steps set with Select function | ||||||||||||
| 16 | Copy | Copy steps from selected # to #. Step # can be edited by Select function | ||||||||||||
| 17 | Paste | Paste copied steps starting from # step. Step # can be edited by Select function | ||||||||||||
| 18 | F1 (Clear) | (Press&Hold) Wipe selected track. Other functions can be assigned in MBSEQ_HW.V4 file | ||||||||||||
| 19 | F2 (Select track) | (Press&Hold) Select track. Other functions can be assigned in MBSEQ_HW.V4 file | ||||||||||||
| 20 | F3 (Select parameter layer) | (Press&Hold) Select parameter layer A,B,C,D…etc. Other functions can be assigned in MBSEQ_HW.V4 file | ||||||||||||
| 21 | F4 (Select trigger layer) | (Press&Hold) Select/assign trigger layer 1..8. Other functions can be assigned in MBSEQ_HW.V4 file | ||||||||||||
| 22 | Rec | Open record menu <html> | Track # | Record{Live; Step} | Mode{Mono; Poly} | AStart{on; off} | Step # | TglGate | Port # | Chn # | </html> | |||
| 23 | « | Rewind. Active only in song mode | ||||||||||||
| 24 | Stop | Stop playback and reset position to beginning | ||||||||||||
| 25 | Play | Start playback of patterns/song | ||||||||||||
| 26 | Pause | Halt/resume playback | ||||||||||||
| 27 | » | Forward. Active only in song mode | ||||||||||||
| 28 | Metronome | Toggle metronome on/off | ||||||||||||
| 29 | Fast | Activate Fast mode for quicker value selection with encoders. Speed options for Fast can be changed in MBSEQ_HW.V4 file | ||||||||||||
| 30 | Scrub | (Press&Hold) + Jog Wheel dynamically change actual position | ||||||||||||
| Menu functions | ||||||||||||||
| 31 | Menu+Scrub | Toggle loop mode on/off | ||||||||||||
| 32 | Menu+GP1 (Mixer) | Open mixer view for 16 tracks. 12 pages can be switched with +/-. An additional options available with Select button More details? <html> | Midi port | Midi channel | Prog change | Volume | Panorama | Reverb | Chorus | CC1 | CC2 | CC3 | CC4 | </html> |
| 33 | Menu+GP2 (Event) | Open track setup editor <html> | Track # | Type{Note; Chord; CC; Drum} | Step # | ParL # | TrgL # | Port # | Chn # | Edit Name | </html> | |||
| 34 | Menu+GP3 (Mode) | Open track mode editor <html> | Track # | Track on/off | Normal, Transpose, Arpeggiator | </html> <html> | ||||||||
Hold{on; off} | Sort{on; off} | Restart{on; off} | Scale{on; off} | Sustain{on; off} | </html> |
| 35 | Menu+GP4 (Direction) | Open track playback direction editor <html> | Track # | Select playback mode: Forward, Backward, PingPong, Pendulum, Rand.Dir, Rand.Step, Rand.D+S | </html> <html> | Fwd # | Back # | Replay # | Repeat # | Skip # | Itv # | SyncM{yes; no} | </html> | |||||||||||||||||||||||||||||||||||
| 36 | Menu+GP5 (Divider) | Open track clock divider setup editor <html> | Track # | Clock # | Divider{normal; triplet} | Sync to Measure{on; off} | Timebase selector: 1, 2, 4, 8 ..etc | </html> | ||||||||||||||||||||||||||||||||||||||||
| 37 | Menu+GP6 (Length) | Open track length editor <html> | Track # | Length # | Loop # | Quick length selection: 4, 8, 16 ..etc | </html> | |||||||||||||||||||||||||||||||||||||||||
| 38 | Menu+GP7 (Transpose) | Open track transpose editor <html> | Track # | Transpose selector: -7 oct … +7 oct | -7 sem … +7 sem | </html> | ||||||||||||||||||||||||||||||||||||||||||
| 39 | Menu+GP8 (Groove) | Open track groove editor <html> | Track # | Groove style{off; shuffle … etc} | Intensity # | Step # | Dly # | Len # | Vel # | Num Steps # | </html> | |||||||||||||||||||||||||||||||||||||
| 40 | Menu+GP9 (Trigger) | Open track trigger layer selection menu <html> | Gate | Acc | Roll | Glide | Skip | R.G(random gate) | R.V(random value) | No FX | </html> | |||||||||||||||||||||||||||||||||||||
| 41 | Menu+GP10 (FX) | Open FX editor <html> | Local{Echo; Hum; Limit; LFO} | Global{Loop; Scale} | </html> <html> ·[Echo] | Track # | Repeats # | Delay # | Vel.Lev # | FB Velocity % | Note # | Gatelen % | Tcks % | </html> <html> ·[Hum] | Track # | Intensity # | Note{on; off} | Vel/CC{on; off} | Length{on; off} | </html> <html> ·[Limit] | Track # | Lower # | Upper # | </html> <html> ·[LFO] | Track # | Wave{off; sine ..etc} | Amp # | Phs % | Steps # | Rst # | OneShot{on; off} | </html> <html> | Note{on; off} | Vel{on; off} | Len{on; off} | CC{on; off} | ExtraCC # | Offs # | PPQN # </html> <html> ·[Loop] | Mode{all tracks / step view ..etc} | Offset # | Steps # | Loop{on; off]} </html> <html> ·[Scale] | Control{global, G1, G2 ..etc} | Root{Keyb, C …etc} | Selected scale{major; minor …etc} </html> |
| 42 | Menu+GP11 (Manual trigger) | Manualy trigger steps, (Press&Hold)+Select for sync to measure <html> | </html> options? | |||||||||||||||||||||||||||||||||||||||||||||
| 43 | Menu+GP12 (Morph) | Open track morphing setup <html> | Track # | Mode{on; off} | Dst.Range # | Value # | Morphing control (also by CC1) | </html> | ||||||||||||||||||||||||||||||||||||||||
| 44 | Menu+GP13 (BPM) | Open BPM settings editor Options for In and Out? <html> | Mode{Auto; Slave; Master} | Preset # | Tempo # | Ramp sec. | Fire Preset | Preset Page | </html> <html> | MClk{USB1 ..etc} | In (?) | Out (?) | Din PPQN # | Ext.Restart | Tap Tempo | </html> | ||||||||||||||||||||||||||||||||
| 45 | Menu+GP14 (Save) | Open save menu <html> | Group # | Location # | Target # | Save | Category | Label | </html> | |||||||||||||||||||||||||||||||||||||||
| 46 | Menu+GP15 (MIDI) | Opens midi setup editor <html> ·[Transpose and arp] Port # | Chn # | T/A Split{on; off} | Midd.Note # | Reset Stcks</html> <html> ·[Section Control] Port # | Chn # | G1 # | G2 # | G3 # | G4 # | Fwd port | Reset Stcks</html> <html> ·[Midi Router] Node # | In port | Chn # | Out port | Chn # | Default Port</html> <html> ·[Misc] BLM_Scalar port{on; off} | Midi Monitor </html> | |||||||||||||||||||||||||||||
| 47 | Menu+GP16 (SysEx) | SysEx operations Options? | ||||||||||||||||||||||||||||||||||||||||||||||
| Utility functions | ||||||||||||||||||||||||||||||||||||||||||||||||
| 48 | Utility+GP1 (Track Select) | Select active track | ||||||||||||||||||||||||||||||||||||||||||||||
| 49 | Utility+GP2 (Copy) | Copy steps from selected # to #. Step # can be edited by Select function | ||||||||||||||||||||||||||||||||||||||||||||||
| 50 | Utility+GP3 (Paste) | Paste copied steps starting from # step. Step # can be edited by Select function | ||||||||||||||||||||||||||||||||||||||||||||||
| 51 | Utility+GP4 (Clear) | Wipe the track. No options - Wipes the track instantly!!! | ||||||||||||||||||||||||||||||||||||||||||||||
| 52 | Utility+GP5 (Move) | Move selected steps (like copy and paste together) | ||||||||||||||||||||||||||||||||||||||||||||||
| 53 | Utility+GP6 (Scroll) | Scroll the steps across | ||||||||||||||||||||||||||||||||||||||||||||||
| 54 | Utility+GP7 (Random) | Generates random events <html> | Track # | Generate | Clr | Util | Undo | LayerA # | LayerB # | LayerC # | TrgA # | Trg B # | Trg C # | </html> | ||||||||||||||||||||||||||||||||||
| 55 | Utility+GP8 (Undo) | Undo last Paste, Clear, Move, Scroll, Random operation | ||||||||||||||||||||||||||||||||||||||||||||||
| 56 | Utility+GP9 (Save) | Open save menu <html> | Group # | Location # | Target # | Save | Category | Label | </html> | |||||||||||||||||||||||||||||||||||||||
| 57 | Utility+GP10 (Record) | Open record menu <html> | Track # | Record{Live; Step} | Mode{Mono; Poly} | AStart{on; off} | Step # | TglGate | Port # | Chn # | </html> | |||||||||||||||||||||||||||||||||||||
| 58 | Utility+GP11 (Mixer) | Open mixer view for 16 tracks. 12 pages can be switched with +/-. An additional options available with Select button More details? <html> | Midi port | Midi channel | Prog change | Volume | Panorama | Reverb | Chorus | CC1 | CC2 | CC3 | CC4 | </html> | ||||||||||||||||||||||||||||||||||
| 59 | Utility+GP12 (Options) | Open options menu <html> | Measure # | Pattern # | SyncChange (on, off) | Paste/Clr steps | </html> <html> | Remote{auto;client;server} | ID # | Port # | Request connection{no} | </html> | ||||||||||||||||||||||||||||||||||||
| 60 | Utility+GP13 (Port Mute) | Access output port muting menu <html> | Def | USB1 | USB2 …etc… AOUT | Bus1 | Bus2 | </html> | ||||||||||||||||||||||||||||||||||||||||
| 61 | Utility+GP14 (Disk) | Open disk menu <html> MSD USB{disabled; enabled/Pres&Hold/} | Midi files{import; export; play} </html> | |||||||||||||||||||||||||||||||||||||||||||||
| 62 | Utility+GP15 (Mute) | Quick mute of all tracks/channels | ||||||||||||||||||||||||||||||||||||||||||||||
| 63 | Utility+GP16 (Unmute) | Quick unmute of all tracks/channels | ||||||||||||||||||||||||||||||||||||||||||||||
midibox_seq_quick_reference.1273419778.txt.gz · Last modified: 2010/05/09 15:42 by gjvti
