midibox_sid_faq [2008/03/03 13:22] SLP |
midibox_sid_faq [2011/08/05 08:04] lauraholden |
Line 145: | Line 145: | ||
This is described in the JSynthLib guide [[http://www.ucapps.de/jsynthlib.html]] | This is described in the JSynthLib guide [[http://www.ucapps.de/jsynthlib.html]] | ||
===== How do I supply power to the MIDIbox SID? ===== | ===== How do I supply power to the MIDIbox SID? ===== | ||
Line 153: | Line 154: | ||
Though a single power supply may work, the voltage needs to be high enough to supply the regulator on your SID board. Because of the higher input voltage, the 5V (7805) regulators on your CORE module(s) will get very hot, especially if you are powering a backlit LCD. | Though a single power supply may work, the voltage needs to be high enough to supply the regulator on your SID board. Because of the higher input voltage, the 5V (7805) regulators on your CORE module(s) will get very hot, especially if you are powering a backlit LCD. | ||
+ | For powering 2core with 2 sid 8580 with a complete (Step C) control surface a 1A/12V power supply should be sufficient sufficient. you can buy 7805 and 7809 regulator that supports up to 1A and chain them togheter (the PSU connectet to the 7809 and the 7805 connected to the 7809 output). | ||
//(Note that 7800-series voltage regulators typically require an input voltage of 3V above their output voltage)// | //(Note that 7800-series voltage regulators typically require an input voltage of 3V above their output voltage)// | ||
Line 319: | Line 322: | ||
To avoid ground loops, it is recommended to use Vd and Vs from J2 of the Core module instead of J10. | To avoid ground loops, it is recommended to use Vd and Vs from J2 of the Core module instead of J10. | ||
+ | [[http://cvresumewritingservices.org/|resume writing services]] | ||
