midibox_speakjet [2007/03/15 00:39] audiocommander |
midibox_speakjet [2016/06/09 01:17] psykhaze [Where to buy ?] |
Line 1: | Line 1: | ||
====== MIDIBox SpeakJet ====== | ====== MIDIBox SpeakJet ====== | ||
- | ===== What is it? ===== | + | \\ |
[[http://www.ucapps.de/mbhp_iic_speakjet.html|MIDIBox SpeakJet Synthesiser]] is a project that uses the [[http://www.magnevation.com|Magnevation]][[http://www.speakjet.com/|Speakjet]] controlled by midibox as a standalone synthesizer. | [[http://www.ucapps.de/mbhp_iic_speakjet.html|MIDIBox SpeakJet Synthesiser]] is a project that uses the [[http://www.magnevation.com|Magnevation]][[http://www.speakjet.com/|Speakjet]] controlled by midibox as a standalone synthesizer. | ||
The SpeakJet IC was brought to market in February 2004, and is available from a variety of vendors for around $25 USD. | The SpeakJet IC was brought to market in February 2004, and is available from a variety of vendors for around $25 USD. | ||
+ | {{youtube>small:EWSybnx2SOM}} | ||
Line 17: | Line 19: | ||
To build this Midi-playable nifty synthesizer project, you will need: | To build this Midi-playable nifty synthesizer project, you will need: | ||
* 1 MBHP Core Module (PIC18F, host of kII speakJet application -> see below, communicates via IIC with the SJ-IIC-Module) | * 1 MBHP Core Module (PIC18F, host of kII speakJet application -> see below, communicates via IIC with the SJ-IIC-Module) | ||
* 1 MBHP SpeakJet-ICC-Module (PIC16F, receives IIC commands from Core and communicates via Serial Transmission with the Speakjet -> breadboard construction described below) | * 1 MBHP SpeakJet-ICC-Module (PIC16F, receives IIC commands from Core and communicates via Serial Transmission with the Speakjet -> breadboard construction described below) | ||
- | * 1 2x16 LCD, optional (displays last sent commands and various settings) | + | * 1 LCD, optional (2x16 for kII v 0.1.x; 1x8 LCD for kII v 0.2.x) |
+ | ====== Where to buy ? ======= | ||
+ | [[https://www.sparkfun.com/products/9578|Sparkfun]] | ||
+ | [[http://www.speechchips.com/shop/item.aspx?itemid=6|Speechchips]] | ||
+ | [[http://www.lextronic.fr/P3124-circuit-integre-speakjet.html|Lextronic France]] | ||
+ | ====== The MBHP SpeakJet IIC Module ======= | ||
- | ===== The MBHP SpeakJet IIC Module ====== | + | \\ |
This project is in progress at the moment. Please visit the [[http://forum.midibox.org/|Forum]] (and especially [[http://www.midibox.org/forum/index.php?topic=2870.0|the first SpeakJet thread]] or see the links below for more info. | This project is in progress at the moment. Please visit the [[http://forum.midibox.org/|Forum]] (and especially [[http://www.midibox.org/forum/index.php?topic=2870.0|the first SpeakJet thread]] or see the links below for more info. | ||
* [[http://www.ucapps.de/mbhp_iic_speakjet.html|IIC SpeakJet Module]] <sup>uCApps</sup> | * [[http://www.ucapps.de/mbhp_iic_speakjet.html|IIC SpeakJet Module]] <sup>uCApps</sup> | ||
{{http://www.audiocommander.de/picBrowser/phpThumb.php?src=galleries/070305_kII/IMG_7772.jpg&w=250&h=166&q=95&f=.jpg?250x166}} | {{http://www.audiocommander.de/picBrowser/phpThumb.php?src=galleries/070305_kII/IMG_7772.jpg&w=250&h=166&q=95&f=.jpg?250x166}} | ||
**SpeakJet-IIC-Module Breadboard v1.3** | **SpeakJet-IIC-Module Breadboard v1.3** | ||
* **[[SpeakJet Breadboard Construction]]** – Description and How-To of this breadboard construction: | * **[[SpeakJet Breadboard Construction]]** – Description and How-To of this breadboard construction: | ||
Line 39: | Line 47: | ||
* [[http://www.audiocommander.de/downloads/midibox/mbhp_iic_speakjet_13.board.fh11.zip|Breadboard Design with lowPassFilter v1.3]] (FreeHandMX sourcefile with a lot of nice electronical symbols, 264 kB) | * [[http://www.audiocommander.de/downloads/midibox/mbhp_iic_speakjet_13.board.fh11.zip|Breadboard Design with lowPassFilter v1.3]] (FreeHandMX sourcefile with a lot of nice electronical symbols, 264 kB) | ||
* [[http://www.audiocommander.de/picBrowser/picBrowser.php?go=galleries/070305_kII&thumbs=1&q=|Picture Gallery: SpeakJet Breadboard v1.3]] | * [[http://www.audiocommander.de/picBrowser/picBrowser.php?go=galleries/070305_kII&thumbs=1&q=|Picture Gallery: SpeakJet Breadboard v1.3]] | ||
+ | If you need older outdated circuit versions, see [[SpeakJet Dev Archive]] | ||
- | If you need older outdated versions, see [[SpeakJet Dev Archive]] | ||
- | ===== SpeakJet Application Software ===== | + | ====== SpeakJet Application Software ====== |
You need the following Software: | You need the following Software: | ||
- | * Firmware for the SpeakJet-IIC-Module -> [[http://www.ucapps.de/mbhp_iic_speakjet.html|download from uCApps.de/mbhp_iic_speakjet.html]] | + | * **Firmware for the SpeakJet-IIC-Module** -> [[http://www.ucapps.de/mbhp_iic_speakjet.html|download from uCApps.de/mbhp_iic_speakjet.html]] (v 1.0) |
- | * SpeakJet Application Software "kII" for the Core Module -> [[SpeakJet Application Software v 0.1]] | + | * **SpeakJet Application Software kII** |
+ | * v 0.2 (including updated SJ-IIC-Firmware v 1.2) -> [[SpeakJet Application Software v 0.2]] (recommended) | ||
+ | * v 0.1 -> [[SpeakJet Application Software v 0.1]] | ||
+ | * **Phrase-A-Lator** from Magnevation (together with a serial connection to a PC running Windows) is needed if you want to store phrases on the SJ or debug the hardware -- (optional) -> [[http://www.magnevation.com/software.htm|Phrase-A-Lator Download Page]] | ||
- | ===== SpeakJet Controller Extensions ===== | + | ====== SpeakJet Controller Extensions ====== |
Currently some optional add-ons are being developed that allow various control of the MBHP-SpeakJet Project. You can add just one of them or all ;) | Currently some optional add-ons are being developed that allow various control of the MBHP-SpeakJet Project. You can add just one of them or all ;) | ||
- | There will be two controller extensions available shortly for the SpeakJet project: | + | {{youtube>small:qSiMwpbNNsg}} |
- | * [[midibox_speakjet_k64_modul|K64 Keyboard Modul]] (-> from Rio) | + | There are two controller extensions available for the SpeakJet project: |
- | * HandTracker Sensor Matrix (-> from audiocommander, soon!) | + | |
- | More Informations will follow asap !! | + | * **[[http://www.youtube.com/watch?v=qSiMwpbNNsg|HandTracker Sensor Matrix]]** -> from audiocommander, part of the v0.2 release! |
+ | * **[[midibox_speakjet_k64_modul|k64 Keyboard Modul]]** -> from Rio. **Note that an adapted version of the k2 application based on v0.1 is required**. The k64 has some additional synth functions, the original k2 app does not provide atm. Future k2-updates may or may not be compatible with this mod. | ||
- | \\ | + | ====== Further Information... ====== |
- | ===== For Further Information... ===== | + | |
* [[http://www.midibox.org/forum/index.php?topic=2870.0|Midibox.org SpeakJet thread]] | * [[http://www.midibox.org/forum/index.php?topic=2870.0|Midibox.org SpeakJet thread]] |
