midibox_tia [2017/06/29 08:03] antichambre [Customized Labels] |
midibox_tia [2018/06/23 20:48] antichambre [Firmware] |
Line 888: | Line 888: | ||
* <wrap download>{{:mbtia_testtone.zip|MIDIbox TIA Test Tone Tool}}</wrap>\\ | * <wrap download>{{:mbtia_testtone.zip|MIDIbox TIA Test Tone Tool}}</wrap>\\ | ||
* <wrap todo>MIDIbox TIA BankStick Check and Debug Tool</wrap>\\ | * <wrap todo>MIDIbox TIA BankStick Check and Debug Tool</wrap>\\ | ||
+ | * <wrap download>[[https://drive.google.com/file/d/0B8IO3f-Xz3O4VTNSM2dCSVVYcDg/edit?usp=sharing|Max Manager]]</wrap> | ||
=== Documentation: ==== | === Documentation: ==== | ||
Line 902: | Line 903: | ||
{{ :mb_tia_manager_main.png | MidiBox TIA Manager - Main page}}\\ | {{ :mb_tia_manager_main.png | MidiBox TIA Manager - Main page}}\\ | ||
{{ :mb_tia_manager_mods.png | MidiBox TIA Manager - Modulation page}} | {{ :mb_tia_manager_mods.png | MidiBox TIA Manager - Modulation page}} | ||
</WRAP> | </WRAP> | ||
<WRAP clear></WRAP> | <WRAP clear></WRAP> | ||
Line 1060: | Line 1063: | ||
Refer to the [[http://www.midibox.org/dokuwiki/doku.php?id=midibox_tia#downloads|download section]] on this page.\\ | Refer to the [[http://www.midibox.org/dokuwiki/doku.php?id=midibox_tia#downloads|download section]] on this page.\\ | ||
Base and Cartridge versions firmware are the same, only the asm setup differs.\\ | Base and Cartridge versions firmware are the same, only the asm setup differs.\\ | ||
+ | [[https://www.dropbox.com/s/bfjf11v8xdav585/setup_tia_cartridge.hex?dl=1|Here the Hex file for cartridge version app.]] | ||
Line 1128: | Line 1133: | ||
- | ==== Bulk order ==== | + | ==== Find the kit ==== |
+ | [[https://modularaddict.com/midibox-tia2600synth-partialkit|Modular Addict]] | ||
- | * For the **PCB**, depends on the quantity, but for example for 10 pieces it's **15€** each.I can already solder and burn the PIC. just tell me. | ||
- | * For the **BackPlane**(with drill helper), price is 30€ @Schaeffer, price decreases with quantity, but still very expensive. I've got a CNC then I can make it for **10€**. Just tell me.\\ | ||
- | * I can do a group order for **components** @Mouser, price is about **30€**\\ | ||
- | * Because of my job, I've got a [[http://fr.rs-online.com/web/p/connecteurs-sub-d-idc/0485956/|SubD crimp]]ing tool then I can prepare the **Breakout cable** for you, like this:\\ | ||
- | <WRAP column 45%> | ||
- | {{:antichambre:img_3964_.jpg?|}} | ||
- | </WRAP> | ||
- | For you after to put the others connectors(supplied) on the other side, full breakout cable is **30~40€**, connectors are expensive, but it can be cheaper by reducing their quality.\\ | ||
- | </WRAP>\\ | ||
- | <WRAP clear></WRAP> | ||
- | * If you provide your **Labels**, in AI(with template), I can print it and cut it out as sticker, **5€**.\\ | ||
- | * [[http://midibox.org/forums/profile/5424-psykhaze/|Psykhaze]] and me, we can <del>try to</del> source the **TIA model UM6520P1**(PAL, no separated outputs) for <del>**5€**</del> <wrap em>4€</wrap> each. | ||
- | <wrap hi>Total for this project is less than 120€.</wrap> | ||
- | <WRAP center round 100%> | ||
- | Bulk is closed. | ||
- | ^Status ^Forum Pseudo ^country ^Board Qty ^ PIC ready ^Backplane ^Components ^Breakout cable ^TIA ^Labels(AI file) ^ | ||
- | |Pending|[[http://midibox.org/forums/profile/7584-antichambre/|Antichambre]]|France|3|3|3|3|3|--|{{:antichambre:mb-tia_cartridge-labels_templateandfonts.zip|AI}}| | ||
- | |Pending|[[http://midibox.org/forums/profile/5424-psykhaze/|psykhaze]]|France|2|2|--|--|--|--|--| | ||
- | |Pending|[[http://midibox.org/forums/profile/9447-mrspring/|mrspring]]|Ireland|1|1|1|1|1|--|1(to provide)| | ||
- | |Shipped|[[http://midibox.org/forums/profile/5278-yogi/|yogi]]|USA|2|--|--|--|--|--|--| | ||
- | |Pending|[[http://midibox.org/forums/profile/8285-scrubber/|scrubber]]|UK|1|1|1|1|1|1|1(to provide)| | ||
- | |Pending|[[http://midibox.org/forums/profile/21290-thumper/|thumper]]|Australia|1|1|--|--|--|--|--| | ||
- | |Pending|[[http://midibox.org/forums/profile/11070-academic-planner/|academic-planner]]|USA|3|3|3|3|3|--|--| | ||
- | |Paid|[[http://midibox.org/forums/profile/20788-phatline/|phatline]]|Austria|4|4|--|--|--|4|--| | ||
- | |Paid|[[http://midibox.org/forums/profile/5656-dnode/|dnode]]|NL|1|1|--|--|--|1|--| | ||
- | |Paid|[[http://midibox.org/forums/profile/7862-ermangaver/|ErMangaver]]|Italy|1|1|--|--|--|1|--| | ||
- | |Pending|[[http://midibox.org/forums/profile/22155-geraldwert/|gerald.wert]]|USA|1|1|1|1|--|--|1(Provided)| | ||
- | |<wrap hi>Total</wrap>|--|--|<wrap hi>20</wrap>|<wrap hi>18</wrap>|<wrap hi>9</wrap>|<wrap hi>9</wrap>|<wrap hi>8</wrap>|<wrap hi>7</wrap>|<wrap hi>7</wrap>| | ||
- | </WRAP> | ||
