midibox_tia [2018/06/17 09:21] antichambre [The MIDIbox TIA Manager] |
midibox_tia [2018/07/11 16:07] antichambre [Downloads] |
Line 882: | Line 882: | ||
=== Firmware: === | === Firmware: === | ||
- | * <wrap download>{{:antichambre:midibox_tia.zip|MIDIbox TIA v1beta Firmware }}</wrap>\\ | + | * <wrap download>{{:antichambre:midibox_tia_v1c.zip|MIDIbox TIA v1c Firmware }}</wrap>\\ |
=== Tools: === | === Tools: === | ||
Line 888: | Line 888: | ||
* <wrap download>{{:mbtia_testtone.zip|MIDIbox TIA Test Tone Tool}}</wrap>\\ | * <wrap download>{{:mbtia_testtone.zip|MIDIbox TIA Test Tone Tool}}</wrap>\\ | ||
* <wrap todo>MIDIbox TIA BankStick Check and Debug Tool</wrap>\\ | * <wrap todo>MIDIbox TIA BankStick Check and Debug Tool</wrap>\\ | ||
+ | * <wrap download>[[https://drive.google.com/file/d/0B8IO3f-Xz3O4VTNSM2dCSVVYcDg/edit?usp=sharing|Max Manager]]</wrap> | ||
=== Documentation: ==== | === Documentation: ==== | ||
Line 1063: | Line 1064: | ||
Base and Cartridge versions firmware are the same, only the asm setup differs.\\ | Base and Cartridge versions firmware are the same, only the asm setup differs.\\ | ||
- | [[https://www.dropbox.com/s/oscdpnq767uayxj/setup_tia_cartridge.hex?dl=1|Here the Hex file for cartridge version app.]] | + | [[https://www.dropbox.com/s/bfjf11v8xdav585/setup_tia_cartridge.hex?dl=1|Here the Hex file for cartridge version app.]] |
Line 1104: | Line 1105: | ||
</WRAP> | </WRAP> | ||
<WRAP column 35%> | <WRAP column 35%> | ||
- | Gerald One. | + | Gerald. |
{{:antichambre:mb-tia_cartridge-labels_gerald.png?300 |}} | {{:antichambre:mb-tia_cartridge-labels_gerald.png?300 |}} | ||
Line 1111: | Line 1112: | ||
<WRAP column 40%> | <WRAP column 40%> | ||
- | Scrubber one. | + | Scrubber. |
{{:antichambre:mb-tia_cartridge-labels_scrubber.02.png?300 | }} | {{:antichambre:mb-tia_cartridge-labels_scrubber.02.png?300 | }} | ||
</WRAP>\\ | </WRAP>\\ | ||
Line 1120: | Line 1121: | ||
- | Djo One. | + | Djo. |
{{:antichambre:mb-tia_cartridge-labels_djo.png?300 |}} | {{:antichambre:mb-tia_cartridge-labels_djo.png?300 |}} | ||
Line 1127: | Line 1128: | ||
+ | Wired.\\ | ||
+ | {{:antichambre:mb-tia_cartridge-labels_wired.png?300 | }} | ||
<WRAP clear></WRAP> | <WRAP clear></WRAP> |
