midibox_tia [2018/07/04 16:12] antichambre [Customized Labels] |
midibox_tia [2020/10/19 10:14] antichambre [Customized Labels] |
Line 882: | Line 882: | ||
=== Firmware: === | === Firmware: === | ||
- | * <wrap download>{{:antichambre:midibox_tia.zip|MIDIbox TIA v1beta Firmware }}</wrap>\\ | + | * <wrap download>{{:antichambre:midibox_tia_v1c.zip|MIDIbox TIA v1c Firmware }}</wrap>\\ |
=== Tools: === | === Tools: === | ||
Line 888: | Line 888: | ||
* <wrap download>{{:mbtia_testtone.zip|MIDIbox TIA Test Tone Tool}}</wrap>\\ | * <wrap download>{{:mbtia_testtone.zip|MIDIbox TIA Test Tone Tool}}</wrap>\\ | ||
* <wrap todo>MIDIbox TIA BankStick Check and Debug Tool</wrap>\\ | * <wrap todo>MIDIbox TIA BankStick Check and Debug Tool</wrap>\\ | ||
- | * <wrap download>[[https://drive.google.com/file/d/0B8IO3f-Xz3O4VTNSM2dCSVVYcDg/edit?usp=sharing|Max Manager]]</wrap> | + | * <wrap download>[[https://www.dropbox.com/sh/peq0t9pwu2iysj1/AADRpItaM4f3dVlXcUnHASuma?dl=1|Max Manager]]</wrap> |
=== Documentation: ==== | === Documentation: ==== | ||
Line 1064: | Line 1064: | ||
Base and Cartridge versions firmware are the same, only the asm setup differs.\\ | Base and Cartridge versions firmware are the same, only the asm setup differs.\\ | ||
- | [[https://www.dropbox.com/s/bfjf11v8xdav585/setup_tia_cartridge.hex?dl=1|Here the Hex file for cartridge version app.]] | + | [[https://www.dropbox.com/s/bfjf11v8xdav585/setup_tia_cartridge.hex?dl=1|Here the Hex file for cartridge version app.(Led Meter issue fixed!)]] |
Line 1133: | Line 1133: | ||
<WRAP clear></WRAP> | <WRAP clear></WRAP> | ||
+ | <WRAP column 5%> | ||
+ | </WRAP> | ||
+ | <WRAP column 35%> | ||
+ | KC. | ||
+ | {{:antichambre:mb-tia_cartridge-labels_kc.png?300 |}} | ||
+ | </WRAP> | ||
+ | </WRAP> | ||
+ | <WRAP column 40%> | ||
+ | </WRAP>\\ | ||
+ | <WRAP clear></WRAP> | ||
==== Find the kit ==== | ==== Find the kit ==== | ||
[[https://modularaddict.com/midibox-tia2600synth-partialkit|Modular Addict]] | [[https://modularaddict.com/midibox-tia2600synth-partialkit|Modular Addict]] |
