mididoc:midibox_cv_v2 [2016/06/26 20:37] psykhaze [MBHP Modules Required] |
mididoc:midibox_cv_v2 [2016/06/27 11:15] psykhaze [MBHP Modules Required] |
Line 3: | Line 3: | ||
- | MIDIbox CV V2 is the successor of MIDIbox CV V1 with focus on digital, high-resolution modulation of CV outputs and an enhanced control surface. | + | MIDIbox CV V2 is the successor of [[:midibox_cv_v1|MB-CV]] V1 with focus on digital, high-resolution modulation of CV outputs and an enhanced control surface. |
[[http://www.ucapps.de/midibox_cv_v2.html|Official Ucapps Page]] | [[http://www.ucapps.de/midibox_cv_v2.html|Official Ucapps Page]] | ||
Line 11: | Line 11: | ||
{{youtube>utr23hp2nRM?large}} | {{youtube>utr23hp2nRM?large}} | ||
===== Control Surface Features ===== | ===== Control Surface Features ===== | ||
Line 21: | Line 22: | ||
* optional LED rings for encoders | * optional LED rings for encoders | ||
===== Control Voltages Features ===== | ===== Control Voltages Features ===== | ||
- | * Typically 12bit outputs with common MBHP based [[AOUT Module]]. Internally working with 16bit | + | * Typically 12bit outputs with common MBHP based [[:AOUT Module]]. Internally working with 16bit |
* Volt/Octave (positive and negative) and Herz/Volt characteristic | * Volt/Octave (positive and negative) and Herz/Volt characteristic | ||
* Configurable slew rate to "smooth" the output curve (e.g. if controlled only by 7bit CCs) | * Configurable slew rate to "smooth" the output curve (e.g. if controlled only by 7bit CCs) | ||
Line 44: | Line 46: | ||
* Works in "slow" and "fast" mode. Supports also Key Sync, MIDI Clock Sync and Oneshot. | * Works in "slow" and "fast" mode. Supports also Key Sync, MIDI Clock Sync and Oneshot. | ||
* 4 Modulation Matrices with two sources (incl. constant values), two destination paths (invertable), and operations such as +, -, multiply, XOR, OR, AND, MIN, MAX, <, >, Equal, Sample&Hold | * 4 Modulation Matrices with two sources (incl. constant values), two destination paths (invertable), and operations such as +, -, multiply, XOR, OR, AND, MIN, MAX, <, >, Equal, Sample&Hold | ||
===== MBHP Modules Required ===== | ===== MBHP Modules Required ===== | ||
* [[:stm32f4_core_board_parts_list|Core32 STM32F4]] | * [[:stm32f4_core_board_parts_list|Core32 STM32F4]] | ||
- | * [[Aout Module]] or [[Aout_ng]] Module | + | * [[:Aout Module]] or [[:Aout_ng]] Module |
- | * [[Ainser8 Module]] | + | * [[:Ainser8 Module]] |
- | * [[Din Module]] | + | * [[:Din Module]] |
- | * [[Dout Module]] | + | * [[:Dout Module]] |
- | * [[SCS Module]] | + | * [[:SCS Module]] // (Optional)// |
===== Options ===== | ===== Options ===== | ||
Line 65: | Line 69: | ||
==== Led Rings Encoders ==== | ==== Led Rings Encoders ==== | ||
+ | {{ :mididoc:neonking:midibox_cv2_lre8x2.jpg?direct&500 |}} | ||
Up to 32 free assignable rotary encoder functions with support for LED rings are available. The encoders have to be connected to a MBHP_DIN module, the LED rings to four shift registers of a MBHP_DOUT module. | Up to 32 free assignable rotary encoder functions with support for LED rings are available. The encoders have to be connected to a MBHP_DIN module, the LED rings to four shift registers of a MBHP_DOUT module. | ||
- | **[[mb-lre8x2cs_pcb|Led Rings Encoders Wiki Page]] ** | + | **[[:mb-lre8x2cs_pcb|LRE8x2 Page]] ** |
