mididoc:midibox_cv_v2
MIDIbox CV V2
Introduction
MIDIbox CV V2 is the successor of MIDIbox CV V1 with focus on digital, high-resolution modulation of CV outputs and an enhanced control surface.
Official Ucapps Page
Video Demo
Control Surface Features
  • a “Standard Control Surface” (SCS), compatible to various other MIDIbox projects, which gives (a cumbersome) access to all parameters.
  • the display used for the SCS can either be a 2×20 character LCD (CLCD), or a 128×64 graphical LCD. The graphical LCD will also print a scope!
  • support for 4 OLEDs which are used as scopes! CV channels can be assigned to the scope displays individually. Selectable oversampling rate and trigger level.
  • all parameters are also bidirectionally accessible via NRPN, this is demonstrated by a sophisticated Lemur template, running on an iPad. A PC/Mac based solution (e.g. based on Ctrlr) is feasible as well
  • user configurable buttons (up to 32)
  • user configurable rotary encoders (up to 16)
  • optional LED rings for encoders
Control Voltages Features
  • Typically 12bit outputs with common MBHP based AOUT Module. Internally working with 16bit
  • Volt/Octave (positive and negative) and Herz/Volt characteristic
  • Configurable slew rate to “smooth” the output curve (e.g. if controlled only by 7bit CCs)
  • Selectable MIDI port (USB/MIDI/OSC), can also listen to multiple ports
  • Selectable MIDI channel and keyboard range (if it listens to MIDI notes)
  • Can listen to MIDI Note, Velocity, Aftertouch, CC, NRPN (14bit), PitchBender (14bit)
  • Portamento, Glide, Glissando
  • Octave Transpose, Semitone Transpose, Finetune, Pitch Range for incoming PitchBender events in MIDI Note mode.
  • Legato, SusKey (fingered portamento)
  • Poly chain mode to combine multiple CV for controlling multiple VCOs
  • Arpeggiator with Up/Down/Up&Down, Random, etc. modes. Options: Sort, Sync, Oneshot, Constant Arp Cycle rate, Easy&Expert play, Speed and Gatelength.
  • 303-like Bassline Sequencer with up to 32 steps and 8 sequences. Supports also Glide and Accent
  • 2 LFOs with Amplitude, Rate, Delay, Phase and predefined modulation targets CV output, LFO2/1 Amplitude, LFO2/1 Rate, ENV1/2 Rate.
  • Various waveforms such as Sine, Saw, Pulse, Random, Positive Sine/Saw/Pulse, etc. Works in “slow” (0.008..44 Hz) and “fast” mode (up to 440 Hz). Supports also Key Sync, MIDI Clock Sync and Oneshot
  • 1 simple ENV with Amplitude, Delay, Attack, Decay, Sustain, Release and predefined modulation targets CV output, LFO2/1 Amplitude, LFO2/1 Rate,
  • Supports Linear and Exponential curve.
  • Works in “slow” and “fast” mode. Supports also Key Sync, MIDI Clock Sync and Oneshot.
  • 1 multi-stage ENV with Amplitude, Offset, Rate, 16 steps with selectable loop and sustain step and predefined modulation targets CV output, LFO2/1 Amplitude, LFO2/1 Rate.
  • 4 Modulation Matrices with two sources (incl. constant values), two destination paths (invertable), and operations such as +, -, multiply, XOR, OR, AND, MIN, MAX, <, >, Equal, Sample&Hold
MBHP Modules Required
Options
Scope Display
Up to 4 SSD1306 based “scope displays” can be connected to display CV output waveforms with a selectable oversampling rate and trigger level
Core32 STM32F4 Interconnection
Led Rings Encoders
Up to 32 free assignable rotary encoder functions with support for LED rings are available. The encoders have to be connected to a MBHP_DIN module, the LED rings to four shift registers of a MBHP_DOUT module.
LRE8x2
mididoc/midibox_cv_v2.1466975022.txt.gz · Last modified: 2016/06/26 21:03 by psykhaze
