Both sides previous revision Previous revision | Next revision Both sides next revision | ||
mididoc:midibox_kb [2016/03/24 10:14] fantomxr |
Line 17: | Line 17: | ||
For MB_NG: If it works like you expected enter //save <filename>//. | For MB_NG: If it works like you expected enter //save <filename>//. | ||
For MB_KB: If it works like you expected enter //store//. | For MB_KB: If it works like you expected enter //store//. | ||
For MB_NG: You will notice that there will be a new file on the sd-card called <filename>.NGK. This file contains the slowest-delays for every single key. Here you can adjust every single key by adjusting the values. The keys are numbered where 0 is the lowest note on an 88-key keyboard (A). | For MB_NG: You will notice that there will be a new file on the sd-card called <filename>.NGK. This file contains the slowest-delays for every single key. Here you can adjust every single key by adjusting the values. The keys are numbered where 0 is the lowest note on an 88-key keyboard (A). | ||
For MB_KB: If you would like to change the slowest-delay of a single key simply enter //set kb <1|2> key_calibration_value <key> <value>// | For MB_KB: If you would like to change the slowest-delay of a single key simply enter //set kb <1|2> key_calibration_value <key> <value>// |
