mididoc:midibox_kb [2016/03/24 10:14] fantomxr |
mididoc:midibox_kb [2016/03/24 10:17] fantomxr |
Line 15: | Line 15: | ||
When you are finished enter //set kb <1|2> calibration off// and play the keybed with your favorite sound. You can take a view on the measured delays by entering //kb1 delays// in the terminal. | When you are finished enter //set kb <1|2> calibration off// and play the keybed with your favorite sound. You can take a view on the measured delays by entering //kb1 delays// in the terminal. | ||
- | For MB_NG: If it works like you expected enter //save <filename>//. | + | For **MB_NG**: If it works like you expected enter //save <filename>//. |
- | For MB_KB: If it works like you expected enter //store//. | + | |
- | For MB_NG: You will notice that there will be a new file on the sd-card called <filename>.NGK. This file contains the slowest-delays for every single key. Here you can adjust every single key by adjusting the values. The keys are numbered where 0 is the lowest note on an 88-key keyboard (A). | + | |
- | For MB_KB: If you would like to change the slowest-delay of a single key simply enter //set kb <1|2> key_calibration_value <key> <value>// | + | |
+ | For **MB_KB**: If it works like you expected enter //store//. | ||
- | With the calibration-mode another change was made. You still have the “slowest_delay”-parameter in MBKB and MBNG. This value now changes the sensitivity per mille. A value of 1000 uses the delays in the .NGK-file = no change. A value of 2000 would double the measured delays - a value of 500 halves the measured delays. | + | For **MB_NG**: You will notice that there will be a new file on the sd-card called <filename>.NGK. This file contains the slowest-delays. Here you can adjust every single key by changing the values. The keys are numbered where 0 is the lowest note on an 88-key keyboard (A). |
+ | For **MB_KB**: If you would like to change the slowest-delay of a single key simply enter //set kb <1|2> key_calibration_value <key> <value>// | ||
+ | With the calibration-mode another change was made. You still have the //slowest_delay//-parameter in MBKB and MBNG. This value now changes the sensitivity per mille. A value of 1000 uses the delays in the .NGK-file = no change. A value of 2000 would double the measured delays - a value of 500 halves the measured delays. |
