Hardwareinfos: http://www.ucapps.de/midibox_kb.html
As I work a lot with keybeds from Fatar and I was looking for an electronic that work with it I found MIDIbox to be the best solution for me. I had a bunch of different keybeds in my hands and I noticed, that some keys are more sensitive than others. So I asked TK to implement a calibration-mode to overcome this issue. With the calibration-mode it is possible to adjust the slowest-delay of every single note on the keyboard. Here is how it works:
Enter set kb <1|2> calibration on in the MIOS Terminal. Now you either have to press every key with the exact same velocity which is nearly impossible or (and that’s the way I do it) use a long piece of wood and press down all white keys and after that all black keys at the same time.
When you are finished enter set kb <1|2> calibration off and play the keybed with your favorite sound. You can take a view on the measured delays by entering kb1 delays in the terminal.
For MB_NG: If it works like you expected enter save <filename>. For MB_KB: If it works like you expected enter store.
For MB_NG: You will notice that there will be a new file on the sd-card called <filename>.NGK. This file contains the slowest-delays for every single key. Here you can adjust every single key by adjusting the values. The keys are numbered where 0 is the lowest note on an 88-key keyboard (A). For MB_KB: If you would like to change the slowest-delay of a single key simply enter set kb <1|2> key_calibration_value <key> <value>
With the calibration-mode another change was made. You still have the “slowest_delay”-parameter in MBKB and MBNG. This value now changes the sensitivity per mille. A value of 1000 uses the delays in the .NGK-file = no change. A value of 2000 would double the measured delays - a value of 500 halves the measured delays.
