Utility Functions
[WORK IN PROGRESS]
The Utility Functions Menu is accessible by pressing MENU + GP Button #10, or the F1 button on the Wilba Frontpanel. Some of these functions (eg: COPY, PASTE, CLEAR) are directly accessible from the Frontpanel without having to go though a menu.
COPY and PASTE
Press COPY to make a copy a portion of the currently selected track into the SEQ's copy buffer. By default, the visible steps will be copied (ie: steps 1-16 if the SEQ's LCD is displaying the start of your pattern.) The COPY function works this way in most modes - if you're in any mode other than EDIT view, the SEQ will switch to EDIT - Step View while the COPY button is held, and will revert back to the previous view when the button is released.
While COPY is held down, you can select the range of steps that will be copied (remember: by default COPY copies the 16 visible steps). Move Encoder #1 to select the first step in the range, and any other encoder (including the datawheel) to select the last step in the range.
COPY/PASTE In SONG Mode
COPY copies the song position.
COPY/PASTE With MIXER MAPS
In MIXER MAP mode, COPY copies the entire current MIXER MAP into the copy buffer. If you move to another Mixer Map and press paste, that map will now be identical to the one you copied.
MENU+COPY and MENU+PASTE
Press MENU+COPY to export all currently selected tracks into the /PRESETS folder on the SD Card. The resulting files are named COPY[track].V4T. The [track] numbers in the filenames are independent from the actual track position - eg: if you select tracks 2, 4 and 6 on the SEQ, then press MENU+COPY, those tracks will be saved as COPY1.V4T, COPY2.V4T, and COPY3.V4T.
Press MENU+PASTE to import “COPY[track].V4T” files from the /PRESETS folder into all selected tracks, starting from COPY1.V4T to (up to) COPY16.V4T - eg: if you select tracks 1 and 7 on the SEQ, then press MENU+PASTE, COPY1.V4T will be copied into track 1 on the SEQ, and COPY2.V4T will be copied into track 7.
You can use these functions to quickly copy and paste tracks between patterns and sessions, to create temporary backups, to duplicate tracks, or whatever. Note that you can also import these COPY[track].V4T files from the MENU→Event→PRESETS menu. You may want to do this if you want to exclude certain parts of the preset.
CLEAR
MOVE
SCROLL
UNDO
A button is available to directly activate the UNDO function, but by default it is not assigned on the Wilba Frontpanel. You can assign the function to a button by editing the MBSEQ_HW.V4 file.
You can also access the UNDO function through the Utility Functions Menu (MENU+GP Button #10 or F1 Button).
The UNDO function reverts the most recent COPY, PASTE, CLEAR, MOVE, SCROLL, or Random Generator operation
