mididocs:seq:usingblm [2014/09/21 06:12] borfo [Using the Button LED Matrix (BLM)] |
mididocs:seq:usingblm [2014/09/21 13:39] borfo [Grid View] |
Line 56: | Line 56: | ||
**Drum Tracks:** in GRID view, each row represents one of the drum instruments. Some drum tracks have 16 instruments - if you're using a 16x8+X BLM, you'll only be able to see 8 instruments at a time. Press ALT+track select buttons to switch between instruments 1-8 and 9-16. | **Drum Tracks:** in GRID view, each row represents one of the drum instruments. Some drum tracks have 16 instruments - if you're using a 16x8+X BLM, you'll only be able to see 8 instruments at a time. Press ALT+track select buttons to switch between instruments 1-8 and 9-16. | ||
+ | **Switching Octaves:** Press ALT+track select buttons to change the octave that is displayed on the BLM. (except on drum tracks - see above) | ||
====Track View==== | ====Track View==== | ||
TRACK View displays multiple tracks across the horizontal access of the BLM. Each Row represents one track. More specifically, each row represents one Trigger Layer of one track. By default, Gate is displayed. You can toggle the selected trigger layer on and off by pressing the BLM buttons. | TRACK View displays multiple tracks across the horizontal access of the BLM. Each Row represents one track. More specifically, each row represents one Trigger Layer of one track. By default, Gate is displayed. You can toggle the selected trigger layer on and off by pressing the BLM buttons. | ||
Line 64: | Line 66: | ||
====Keyboard View==== | ====Keyboard View==== | ||
- | In KEYBOARD mode, each column of BLM buttons will play a note, and moving up or down will play the note with a different velocity. | + | In KEYBOARD mode, each column of BLM buttons will play a note, and moving up or down will play the note with a different velocity. Rows closest to the top of the BLM play notes quietly, and the note will get louder as you move closer to the bottom of the BLM. |
====303 View==== | ====303 View==== | ||
303 View is not accessible on 16x8+X BLM configurations. | 303 View is not accessible on 16x8+X BLM configurations. | ||
