Both sides previous revision Previous revision | |||
mididocs:seq:usingblm [2014/09/21 06:20] borfo [Keyboard View] |
mididocs:seq:usingblm [2014/09/21 13:39] borfo [Grid View] |
Line 56: | Line 56: | ||
**Drum Tracks:** in GRID view, each row represents one of the drum instruments. Some drum tracks have 16 instruments - if you're using a 16x8+X BLM, you'll only be able to see 8 instruments at a time. Press ALT+track select buttons to switch between instruments 1-8 and 9-16. | **Drum Tracks:** in GRID view, each row represents one of the drum instruments. Some drum tracks have 16 instruments - if you're using a 16x8+X BLM, you'll only be able to see 8 instruments at a time. Press ALT+track select buttons to switch between instruments 1-8 and 9-16. | ||
+ | **Switching Octaves:** Press ALT+track select buttons to change the octave that is displayed on the BLM. (except on drum tracks - see above) | ||
====Track View==== | ====Track View==== | ||
TRACK View displays multiple tracks across the horizontal access of the BLM. Each Row represents one track. More specifically, each row represents one Trigger Layer of one track. By default, Gate is displayed. You can toggle the selected trigger layer on and off by pressing the BLM buttons. | TRACK View displays multiple tracks across the horizontal access of the BLM. Each Row represents one track. More specifically, each row represents one Trigger Layer of one track. By default, Gate is displayed. You can toggle the selected trigger layer on and off by pressing the BLM buttons. |
