mididocs:v4l:midiprocessing [2014/09/15 02:23] borfo |
mididocs:v4l:midiprocessing [2014/09/15 02:25] borfo |
Line 8: | Line 8: | ||
Now would be a good time to flash your V4L with the latest [[http://ucapps.de/mios32_download.html|firmware]], using [[http://ucapps.de/mios_studio.html|MIOS Studio]]. After flashing the firmware, enter the "store" command in MIOS Studio's command line. This will write all of the new parameters you'll be using in the configuration files on your V4L, so you can edit them as set out below. | Now would be a good time to flash your V4L with the latest [[http://ucapps.de/mios32_download.html|firmware]], using [[http://ucapps.de/mios_studio.html|MIOS Studio]]. After flashing the firmware, enter the "store" command in MIOS Studio's command line. This will write all of the new parameters you'll be using in the configuration files on your V4L, so you can edit them as set out below. | ||
- | **To enable force-to-scale on incoming MIDI notes** | + | ===To enable force-to-scale on incoming MIDI notes=== |
- Open the MIOS32 File browser built into MIOS Studio. | - Open the MIOS32 File browser built into MIOS Studio. | ||
- Edit the SESSIONS/DEF_V4L/MBSEQ_C.V4 file. | - Edit the SESSIONS/DEF_V4L/MBSEQ_C.V4 file. | ||
Line 31: | Line 31: | ||
You're done. | You're done. | ||
+ | ===Other MIDI Effects=== | ||
You'll notice that the V4L doesn't just force the incoming MIDI to scale. It also can apply the ECHO, HUMANIZE, and LFO effects to incoming MIDI notes - so your V4L is now a MIDI effects processor. The V4L will apply effects only to the MIDI channels that are selected for SEQ1 and SEQ2. Some of the effects won't work if the V4L playback is stopped. | You'll notice that the V4L doesn't just force the incoming MIDI to scale. It also can apply the ECHO, HUMANIZE, and LFO effects to incoming MIDI notes - so your V4L is now a MIDI effects processor. The V4L will apply effects only to the MIDI channels that are selected for SEQ1 and SEQ2. Some of the effects won't work if the V4L playback is stopped. | ||
You can also record and play back sequences on the V4L while it is processing and forwarding incoming MIDI. | You can also record and play back sequences on the V4L while it is processing and forwarding incoming MIDI. | ||
