Both sides previous revision Previous revision | |||
mididocs:v4l:midiprocessing [2014/09/15 18:03] borfo |
mididocs:v4l:midiprocessing [2014/09/15 19:48] borfo [The V4L as a MIDI Processor] |
Line 9: | Line 9: | ||
===To enable force-to-scale on incoming MIDI notes=== | ===To enable force-to-scale on incoming MIDI notes=== | ||
- Open the MIOS32 File browser built into MIOS Studio. | - Open the MIOS32 File browser built into MIOS Studio. | ||
- | - Edit the SESSIONS/DEF_V4L/MBSEQ_C.V4 file. | + | - Edit the SESSIONS/DEF_V4L/MBSEQ_C.V4 file on your V4L's SD card. Alternately, you can remove the SD card from the V4L, use a card reader on your computer and edit the file directly in a text editor. |
- Find "LiveForceToScale", and set it to 1. If it doesn't exist, add it and set it to 1. But it should exist, because you used the "store" command, right? | - Find "LiveForceToScale", and set it to 1. If it doesn't exist, add it and set it to 1. But it should exist, because you used the "store" command, right? | ||
